Mercedes Injector Problems: Common Issues & Fixes
Buddy
Post10-10-2008, 18:08    Subject: Mercedes Injector Problems: Common Issues & Fixes Quote
Hello everyone,
Since the issue with the intake manifold flaps, the C202 220CDI had been running smoothly again, but now I'm experiencing another problem.
The injector on the 3-cylinder engine is defective.
Now I'm not sure whether there's an internal defect, or if it's just blowing through the cylinder head.
He is definitely leaking; he is clearly expelling air, and I'm not sure where. I just tried using a leak detector, but it's not working as expected icon_sad.gif.
I strongly suspect it's leaking internally, but I don't want to buy a new one without good reason.
Are there any good tips on how I can find this out for sure?
Here are a few more key details.
Engine: 611.960
Year: 12.98
150,000 km
Best regards, Sebastian.
Grüße Buddy
Golf3 Variant TDI Bj95 90PS und 203000km ohne Reparaturen
s202 C220 CDI T Bj98 125PS 133000 mit vielen Reparaturen
Translated on 25-10-2026, 7:41.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post10-10-2008, 18:20    Subject: Mercedes Injector Problems: Common Issues & Fixes Quote
"I am aware of external leaks from the Sprinter, but to identify internal leaks, a comparison of leakage oil with the other injectors is necessary."
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 25-10-2026, 7:43.
Buddy
Post10-10-2008, 18:36    Subject: Mercedes Injector Problems: Common Issues & Fixes Quote
I'm not sure whether to look inward or outward right now.
So, it's clearly blowing out of the "cylinder," and it's both noticeable and audible. Is it blowing *through* the injector, or *past* it?
To check for leaks, should I disconnect the diesel return line and measure where and how much fuel is leaking out?
I still need a new copper gasket, a new screw for the tensioner, and according to the WIS (Workshop Information System), also some "special grease." What kind of grease is that?
I'm not as familiar with the injection system as I am with the rest of the car, so please forgive me if I ask some silly questions icon_wink.gif.
PS: Some sprinters have the same or, let's say, almost the same engine. But you occasionally read about that online. It's not a rare occurrence...
Grüße Buddy
Translated on 25-10-2026, 7:44.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post10-10-2008, 20:36    Subject: Mercedes Injector Problems: Common Issues & Fixes Quote
Buddy wrote:
Hello everyone,
He's definitely wet.
Are there any good tips on how I can find this out for sure? Best regards, Sebastian
For me, "leaking to the outside" means that combustion gases containing unburned diesel fuel/soot are bypassing the injector nozzle seat in the cylinder head and escaping as a black sludge.
"Leaking inwards" means that the amount of leakage is too high.
There are measuring devices that capture the amount of leakage and make it measurable and comparable.
Your statement was contradictory.
It's likely that simply replacing the copper gasket won't solve the problem, because the injector probably loosened itself from the gasket seat and may have damaged it.
The MB workshop will mill the seat flat again before creating a new one.
Translated on 25-10-2026, 7:46.
Buddy
Post10-10-2008, 21:02    Subject: Mercedes Injector Problems: Common Issues & Fixes Quote
Okay, I think I understand you so far.
Unfortunately, I have conflicting information that doesn't make either option clear.
I have a gas leak, but no carbon deposits. Instead, I have diesel and some kind of sludge or grime, whatever you want to call it. It's not black, which is why I don't think it's carbon. Is the diesel fresh or unburned, and then re-expelled?
What's becoming clear to me as I'm writing this is that there was no bubbling when the injector foot was submerged in water, even after I sprayed the leak detector on it.
That certainly suggests a leak inside, doesn't it?
Do you know how they machine the sealing surfaces during the sealing process?
If it's internally damaged, I'm just cleaning it up and not adding any new material. And if I manage to get it out, I should actually be able to do the repair myself.
I'll also quickly make myself a pull-through slot cutter.
Damn, I don't think that's going to happen this weekend. It's a bit too cold to ride the motorcycle right now for the 50km commute to work in the mornings.
Grüße Buddy
Translated on 25-10-2026, 7:49.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post10-10-2008, 21:34    Subject: Mercedes Injector Problems: Common Issues & Fixes Quote
Okay, so, as I know it:
If the injector is leaking externally in the combustion chamber, soot and black sludge will escape from the combustion chamber and contaminate the entire area around the injector.
Solution: Machine a new part for the small seat from above, and replace the sealing washer.
If there's no soot (from starting) and no combustion gas detected through water bubbles or oil, then it can only be either a leaking injector (to the outside) or a leak in the line/connection. In that case, there will clearly be diesel fuel around the area.
Solution: Either a new nozzle or just a fitting/pipe, depending on the location of the leak.
The injector cannot be disassembled on its own because it was pressed together and screwed in under (pre)tension during manufacturing. This requires a special device that even DB workshops don't have, but replacement nozzles are available.
"You say it's releasing a lot of air? Yes, where? But if the leak detector isn't showing any bubbles, how can that be?"
Translated on 25-10-2026, 7:51.
Buddy
Post10-10-2008, 22:01    Subject: Mercedes Injector Problems: Common Issues & Fixes Quote
"There's a real blast of air coming out, it just blows the leak detector away without making any noise icon_wink.gif. It's kind of like blowing really hard into your hand. You can hear it very clearly, even with the engine cover on and the engine compartment closed. It hasn't been there for long, I'd say no longer than a week, maybe just a few days, as long as I haven't driven the car."
I suspect I'll take a closer look at it tomorrow. It seems to be leaking just below the multi-channel connector, which is located near the cable connecting to the rail. However, I'm not entirely sure, as it's very difficult to determine the exact source of the leak.
That's why I'm asking here, because I'm having a lot of trouble pinpointing the exact location. That's my main problem.
I would say it's likely coming from somewhere above or near the seat, because if it were coming from below, I would have gotten a fountain of that diesel mixture all over me, as the air would have blown it away.
"I will definitely turn the engine over manually tomorrow and see if the leak detector produces bubbles without blowing away."
Are there any other ways to test where it might be coming from?
I hope you understand my problem better now.
Grüße Buddy
Translated on 25-10-2026, 7:54.
Buddy
Post11-10-2008, 10:17    Subject: Mercedes Injector Problems: Common Issues & Fixes Quote
Okay, so...
This morning, the world looks completely different.
It seems like I was kind of out of it yesterday.
This morning, I did some searching and checking. So, the injector is sealing properly in its seat.
I manually rotated it once, and it clearly failed the test at that point.
I also found a little bit of oil shale.
It hisses almost directly beneath the tensioner.
Does anyone have a guide for me that explains in detail how to properly seal something?
At the same time, I started getting quotes for a repair at the workshop.
And most importantly, thank you very much for the kind help icon_smile.gif.
Grüße Buddy
Translated on 25-10-2026, 7:56.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Mercedes LMM to VW: Conversion Guide Diesel Engine Technology
No new posts Mercedes Vito 10c: Parts for 1997/98 Models Diesel Engine Technology
No new posts Mercedes OM 601.940 - Revision? Diesel Engine Technology
No new posts Mercedes vs. Physics: The Ultimate Showdown Transmission, Chassis, Body & Interior
