Avenga Guest
09-10-2008, 12:21 Subject: Lift for VW Golf 4 |
I need to quickly find out where to position the lift arms on a Volkswagen Golf 4. Unfortunately, there's no manual included with the vehicle (as there usually is). I need to do the exhaust work tomorrow.
I noticed a large bulge under the driver's side door, near where the jack is usually placed. It looks like someone has definitely been messing around with that area before.
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
09-10-2008, 12:56 Subject: Lift for VW Golf 4 |
Okay, at the designated points on the front and rear sills (near the wheels), where the jack also attaches - read the owner's manual  . Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Profile PM Email Garage |
matthiasTDI96 Profi-Schrauber
09-10-2008, 13:32 Subject: Lift for VW Golf 4 |
Well, if he doesn't have a logbook...
So, I'm going to wash the Golf, and then I'll see some embedded markings in the shape of a triangle on the rocker panel. They specify the height, and then the lifting platform is positioned at that height on the pier.
09-10-2008, 14:11 Subject: Lift for VW Golf 4 |
It also works at the indicated point; you just need to place the 1-meter long piece of wood ("Dielstück") on the plate, which will distribute the lifting force without pressing down on the sill. Gruß, der Teileklaus
Avenga Guest
09-10-2008, 17:40 Subject: Lift for VW Golf 4 |
Okay, so it's the standard way on the sill of the car, near the rear wheel arch. On the Seat Ibiza, there's a specifically designed metal attachment point in the back for the lifting platform (not a jack).
Okay, then I'll check the markings.
09-10-2008, 20:13 Subject: Lift for VW Golf 4 |
Down there, there should be a lot of metal anyway, and it's certainly a given that a car lift or lifting platform should never have plastic panels.
