Document: Performance loss over time, MKB AFB, AKN, AKE, AYM (Solution)
Michael II
Post09-01-2003, 13:49    Subject: Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Quote
Gradual performance loss over time, jerky operation and irregular engine running.
AFB/AKN/AKE/AYM - V6 TDI Engine
Affected Chassis Numbers:
Until: 8E92A 125234
Due to: 4D22N 003699
Due to: 4B22N 046559
Cause:
Possible significant wear of camshafts with deep grooves on the cam lobes in the millimeter range, approximately from 150,000 km, due to the combination of unfavorable tolerances. Irregular engine running and jerking due to changed valve opening angles.
KD-Solution
In case of complaint, specifically hardened camshafts must be installed. As long as the cylinder heads, connecting rods, and hydraulic lifters are in good condition, their replacement is not necessary when using the hardened camshafts.
Share numbers:
Intake Cylinder 4-6 left ......... 059-109-021 P
Entrance Cylinder 1-3 right ...... 059-109-021 Q
Exhaust Cylinder 4-6 left ..... 059-109-022 P
Exhaust Cylinder 1-3 right .. 059-109-022 Q
Tschüss
Michael II
Ratings - Document: Performance loss over time, MKB AFB, AKN, AKE, AYM
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 3 - View ratings
No new posts Doku 4-cylinder. TDI Clattering/Rumbling, Power Loss Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAGCOM Adapter: Performance Requirements Diesel Engine Technology
No new posts ZR Seal Replacement: Performance Loss Troubleshooting On-Board Diagnostics (OBD)
No new posts Leistungsverlust nach A3 belieben... Diesel Engine Technology
No new posts after timing belt replacement, AUY performance loss Diesel Engine Technology
