jensb Guest
08-01-2003, 18:20 Subject: Glow Plug Failure Causes Engine Damage in TDI |
In my Golf TDI 66kW, manufactured in 1998 and with 67,000 km on the odometer, a portion of the glow plug has actually fallen into the combustion chamber, and according to my mechanic, this has caused engine damage.
Is this something that can happen? Do I have any chance of claiming compensation from Volkswagen or Bosch? Have I ever heard of something like this happening before?
Jens.
Translated on 26-10-2026, 5:02.
Bertil Profi-Schrauber
08-01-2003, 18:33 Subject: Glow Plug Failure Causes Engine Damage in TDI |
I've only heard of spark plug fragments causing problems in the pre-chamber of the engine so far, but even there, those fragments can cause significant damage. I wouldn't rule it out as a possibility.
Class action lawsuit against VW?
Defective, unless a manufacturing or material defect is proven.
Regression against Bosch??
Zero, you are not a customer of Bosch, but of VW, and VW is a customer of Bosch.
Translated on 26-10-2026, 5:04.
haehnlein Schrauber
Joined: 08/22/2002 Posts: 877 Karma: +6 / -0 Location: Griesheim
08-01-2003, 19:51 Subject: Glow Plug Failure Causes Engine Damage in TDI |
Hi Jens,
I just clamped the tip of an old, completely defective glow plug into a pair of flat-nose pliers and tried to break it off. It required enormous force to break off the tip  .
I can't really imagine it like that  .
What symptoms did you experience when the engine broke down? My sincere condolences  .
Best regards, Christian.
Translated on 26-10-2026, 5:05.
harrossurfjoker Guest
09-01-2003, 20:27 Subject: Glow Plug Failure Causes Engine Damage in TDI |
Soldering irons typically break when the ESD (electrostatic discharge) system is faulty and/or produces a poor soldering pattern.
Hello.
Translated on 26-10-2026, 5:06.
haehnlein Schrauber
09-01-2003, 20:53 Subject: Glow Plug Failure Causes Engine Damage in TDI |
harrossurfjoker wrote: | | Glue sticks usually break when the extruder (ESD) is defective and/or has a poor extrusion pattern. |
Hi Harro,
I could imagine that happening with mileage exceeding 200,000 km... but at 68,000 km, there would definitely have to have been knocking noises or something similar beforehand  . And a material defect of that magnitude in the spark plug can certainly be ruled out.
I just want to make sure that the workshop isn't telling any lies to avoid honoring the warranty...  For that, we would need more information from the author.
Translated on 26-10-2026, 5:07.
09-01-2003, 21:01 Subject: Glow Plug Failure Causes Engine Damage in TDI |
You're right, that shouldn't happen at 68,000 km. However, anything is possible, and if it's a sporadic ESD (Electrostatic Discharge) issue that the driver might not notice, then it's at least a possibility.
greetings
Hello.
Translated on 26-10-2026, 5:08.
zago Guest
11-01-2003, 21:38 Subject: Glow Plug Failure Causes Engine Damage in TDI |
So, I last saw something like this about 10 years ago on a Mercedes /8, and it destroyed the piston, but nothing else. You could even still drive it  .
