What do the error codes in the error memory mean?
internetnihat
Post10-02-2009, 21:15    Subject: What do the error codes in the error memory mean? Quote
Hello everyone.
I found a few errors, but I don't know how to fix them.
In document number 19, 'SchST Daten Bus,' I found the following errors:
-01207 Control unit for auxiliary heater J364, open circuit.
In item 09, control electronics.
-01314 Engine control unit, open circuit.
-01320 Steurgerät for Climatronic J255, open loop system.
What do these errors mean?
My heater isn't working.
Yesterday, I removed the battery and installed a new one. Could it be related to that?
Nihat
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post10-02-2009, 22:26    Subject: What do the error codes in the error memory mean? Quote
Have you ever deleted something and then checked to see if it was really gone?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
internetnihat
Post10-02-2009, 22:39    Subject: What do the error codes in the error memory mean? Quote
Yes, they were out.
I don't know if they will be there again tomorrow.
Nihat
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post10-02-2009, 22:56    Subject: What do the error codes in the error memory mean? Quote
And did the errors reappear?
internetnihat
Post11-02-2009, 19:10    Subject: What do the error codes in the error memory mean? Quote
All errors have been fixed except for the following issues found in the SchST data bus:
After deleting, it reappears.
Sure, here's the translation:
'MFG' is an abbreviation for 'Mit freundlichen Grüßen,' which translates to 'Sincerely' or 'Best regards' in English.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post11-02-2009, 19:52    Subject: What do the error codes in the error memory mean? Quote
You're saying that your ZH isn't working!
So, I would look for the fault in the power supply there; an open circuit could indicate a broken cable. Is the plug securely connected? Is there power?
I haven't seen the error "open loop" described that way before; it always seems to be followed by a break after the plus or minus sign.
internetnihat
Post11-02-2009, 20:25    Subject: What do the error codes in the error memory mean? Quote
'I had a faulty control unit for the auxiliary heater, and about 3 hours ago I installed a replacement control unit in the auxiliary heater, and it's working, but unfortunately, I'm occasionally getting this error code, which is described as 01207.'
Nihat
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post11-02-2009, 21:00    Subject: What do the error codes in the error memory mean? Quote
Then it might be a bug.
You would need to use the manufacturer's software/tester to read the data – Eberspächer Webasto.
internetnihat
Post15-02-2009, 11:47    Subject: What do the error codes in the error memory mean? Quote
Good morning.
I've cleared the error message multiple times over the past few days, and also turned on the auxiliary heater, and the error message hasn't reappeared.
Thank you for your help.
Sure, here's the translation of the text from German to English:
'MFG nihat' translates to 'Best regards, nihat' or 'Sincerely, nihat.' It's a common German abbreviation for 'Mit freundlichen Grüßen,' which means 'With kind regards' or 'Best regards.'
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts P0148 - Fuel Supply Malfunction General Tips
No new posts Fault quantity setting in the fault memory On-Board Diagnostics (OBD)
No new posts Golf IV, High RPM, Error in Fault Memory On-Board Diagnostics (OBD)
No new posts MSW 1Z: Many errors after cleaning On-Board Diagnostics (OBD)
No new posts VAGCOM Settings: What Do They Mean? Diesel Engine Technology
