Automatic transmission (CKZ) Golf 3, problem, 215,000 km
kapselchrissi
Post12-11-2008, 16:17    Subject: Automatic transmission (CKZ) Golf 3, problem, 215,000 km Quote
Hello Schauber,
'My automatic transmission makes a whistling noise when I release the accelerator, and it's been doing that for about 60,000 kilometers. It's hard to notice under load, but it might be howling then too.' It worked perfectly.
'However, recently a problem has emerged that is causing me more concern. When I start the car, it almost reaches 30 km/h in idle speed, even though the idle speed in neutral is within the normal range.' If I brake suddenly, there's a brief, unusual noise that occurs, which then disappears when I brake more forcefully or when the vehicle is under load again. (This grinding noise can also be interpreted as a loud squealing.)
Is my first gear disengaged? Am I the only one with this kind of experience? Where is the problem, and how can it be fixed? (The transmission oil was changed at approximately 160,000 km to eliminate the whistling noises, but without success.)
I look forward to your responses.
Best regards, Christian.
Post20-11-2008, 21:04    Subject: Automatic transmission (CKZ) Golf 3, problem, 215,000 km Quote
Please read the fault memory of the automatic transmission. It might be running in a failsafe mode.
No new posts ATF (Automatic Transmission Fluid) replacement in the aut... Troubleshooting & Guides
No new posts Automatic Transmission Fluid Change 01M Golf III Troubleshooting & Guides
No new posts Document: Automatic Transmission Leaks 01M Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbo tuning; Golf III TDI with automatic transmission Diesel Engine Technology
No new posts TDI Golf 3: Common Problems & Solutions Diesel Engine Technology
No new posts Golf IV ESP Problem: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Golf III AFN: Temperature Sensor Problem On-Board Diagnostics (OBD)
