Audi A2 Manual Transmission Repair
Post02-12-2008, 11:13    Subject: Audi A2 Manual Transmission Repair Quote
Hello.
ich habe hier einen Audi A2 der enorme Betätigungskräfte für die Handschaltung braucht. Das Problem lässt sich auf die Kugelaufnahme zurückführen in meinen Augen. Die innere Manschette des Schalthebels hat sich aufgelöst und hat die Brösel schön auf die gefettete Kugel verteilt. Der Rest der Schaltung sieht sehr gut aus. Frage jeSure, here's the translation of the text from German to English:
"tz:" translates to "time zone:" in English.
Can the ball joint assembly be disassembled for cleaning? And what should I use to lubricate it after cleaning?
"edit: I just received a tip that there might be problems with the shift cables, and apparently, plastic guides have broken in some cases. I'm not sure what to make of this information. Where should I start looking for the problem – on the transmission side or inside the car?"
Translated on 29-07-2026, 17:56.
Post02-12-2008, 11:19    Subject: Audi A2 Manual Transmission Repair Quote
Yes, it's a 1.4 TDI AMF/EWQ engine.
Translated on 29-07-2026, 17:57.
Post02-12-2008, 12:10    Subject: Audi A2 Gear Shifter Problems & Solutions Quote
matthiasTDI96 wrote:
Die innere Manschette des Schalthebels hat sich aufgelöst und hat die Brösel schön auf die gefettete Kugel verteilt. Der Rest der Schaltung sieht sehr gut aus. Frcurrent age:
edit: I just received a tip that there might be problems with the shift cables; it seems that plastic guides have broken in some cases. I don't understand this hint at all; where should I start looking? Should I investigate on the transmission side or inside the cabin?
Hi Matthias,
"In my opinion, you should be able to feel where the jam is located: If it's directly inside the ball, the gear lever will resist even the slightest movement, almost as if it's stuck in a vise."
When the control cables are engaged, the initial movement is relatively easy, but it becomes increasingly difficult until sufficient force is applied to move the entire facial expression mechanism.
I would clean the ball bearing from above as thoroughly as possible (while shifting through all the gears) and then, while shifting, check if any more rubber debris from the boot becomes visible in the gap between the ball and the socket. If not, the ball is probably not stuck due to rubber debris.
Translated on 29-07-2026, 17:59.
durnesss
Post11-12-2008, 17:30    Subject: Audi A2 Manual Transmission Repair Quote
What else should be checked?
It is the bearing play of the vertical camshaft.
They like to argue.
which often results in water entering the transmission.
This will first cause the camshaft to become difficult to turn (due to rust).
and secondly, the transmission oil turns into a rusty emulsion.
that destroys everything movable inside the transmission.
I just played that game on my car, which also has an ewq transmission.
Thomas.
Translated on 29-07-2026, 18:01.
Post11-12-2008, 19:46    Subject: Audi A2 Manual Transmission Repair Quote
"Yes, that's a good tip; I'll definitely take a look at it as soon as I have access to the car again."
Thank you!
Translated on 29-07-2026, 18:02.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts FIS in the Audi Transmission, Chassis, Body & Interior
No new posts LOG Audi 2.5 AKE Upload
No new posts Audi AFB STG: Repair & Replacement Diesel Engine Technology
