Retrofit LDA for Ibiza 6K 2000: Questions & Answers
Octavia_4x4
Post21-12-2008, 12:40    Subject: Retrofit LDA for Ibiza 6K 2000: Questions & Answers Quote
I'm going to order an oil temperature and LDA (Lean Direct Injection) display from VDO this week.
Okay, I understand everything so far. I want to tap into the boost pressure at the EGR valve, meaning I'll drill a hole in the fitting, insert a threaded stud, and connect a hose.
The real question, however, is:
Of course, air is also being forced into the hose that connects to the gauge. And that hose is about 2 meters long.
1.) Wouldn't this make the display completely sluggish? At least initially, until the tube is "filled," it should be noticeable.
2.) Is the loss of performance due to "air leakage" in the hose?
More broadly, I wonder if an LDA (Linear Drive Accelerator) makes sense for a production engine... Ultimately, it's a shame to only install one display, as the standard dashboard in the 6K Cupra has space for two.
The oil temperature is extremely important to me for protecting the engine, and otherwise, VDO only offers instruments that you really don't need... I don't think things like battery voltage are worth retrofitting.
It would be great if someone could answer the questions mentioned above.
Translated on 22-10-2026, 6:34.
Post21-12-2008, 13:52    Subject: Retrofitting LDA to Ibiza 6K 2000: Questions. Quote
Ibiza1986 wrote:
Of course, air is also forced into the hose that goes to the display. That hose is now about 2 meters long...
1.) Wouldn't that make the gauge completely sluggish? At least initially, until the hose is "filled," shouldn't that be noticeable?
No, the pressure change is so rapid that it reaches the LDA so quickly that, without an extra restriction, the needle can even oscillate wildly in sync with the cylinder pulsations.
No. For that, you would need hoses approximately the size of a garden hose with open ends, which would create significant leaks.
In a broader sense, I wonder if LDA makes sense for a production engine... }Does the LDA technical article not convince you?
Translated on 22-10-2026, 6:37.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post21-12-2008, 14:00    Subject: Retrofit LDA for Ibiza 6K 2000: Questions & Answers Quote
1: The gauge isn't too slow; the tube should have a lumen of more than 1 mm, but it doesn't necessarily need to be 6 mm.
Some people even install a valve to dampen the vibrations. This is done when the needle is jumping or twitching.
Regarding point 2: I guess you wouldn't notice any difference there.
Scientifically speaking, you are likely correct: the more dead volume in the control line, the "slower" the actuator will respond/be regulated. It simply introduces a time delay.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 22-10-2026, 6:39.
EMSimASZ
Post21-12-2008, 14:46    Subject: Retrofit LDA for Ibiza 6K 2000: Questions & Answers Quote
My hose has an inner diameter of 2.5mm. The LDA indicator doesn't flicker or lag; it's working perfectly, as far as I can tell.
I also tapped into the AGR (Abgasrückführung). An LDA (Lambda Probe) is generally always a good idea. You can immediately see if there's something wrong with the turbocharger.
Translated on 22-10-2026, 6:40.
Octavia_4x4
Post21-12-2008, 15:00    Subject: Retrofit LDA for Ibiza 6K 2000: Questions & Answers Quote
Well,
The technical article is quite convincing, especially considering that my charger has 180,000 km on it, was completely inspected at 162,000 km and found to be in excellent condition, and I don't consume any oil.
Ultimately, I'll definitely retrofit the LDA, as I can't think of any other useful display besides the oil temperature.
I just need to figure out how to get a suitable threaded nipple tomorrow.
I'll keep following up on this and report back when I have time... but that might take a while, as I still need to order the parts. Also, the VDO LDA pressure sensor up to 1.5 bar is currently marked as "out of stock" in our IT system.
Translated on 22-10-2026, 6:41.
EMSimASZ
Post21-12-2008, 16:12    Subject: Retrofit LDA for Ibiza 6K 2000: Questions & Answers Quote
'Oil pressure is also a good thing to monitor. Originally, I wanted to have displays in the car showing boost pressure, oil pressure, and oil temperature.'
Translated on 22-10-2026, 6:42.
Octavia_4x4
Post21-12-2008, 16:15    Subject: Retrofit LDA for Ibiza 6K 2000: Questions & Answers Quote
Yes, 3 ads simply don't fit into the original recesses designed for them in the SEAT. I don't want to force anything in; it has to look original.
Boro
Post30-12-2008, 8:16    Subject: Retrofit LDA for Ibiza 6K 2000: Questions & Answers Quote
I have the original oil pressure and voltmeter gauges in the center console of my old Ibiza 6k, and the oil temperature is already displayed in the MFA (multifunction display).
I placed the LDA icon_smile.gif on the upper left side of the dashboard, so that it's easily visible and aesthetically pleasing, with the blue-red color matching the dashboard illumination.
Translated on 22-10-2026, 6:43.
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ibiza 2000: Time Warp Error On-Board Diagnostics (OBD)
No new posts Speedometer Installation Seat Ibiza TDI 2000 Diesel Engine Technology
No new posts RKA Retrofit for 1K0 907 379 AC Transmission, Chassis, Body & Interior
No new posts Retrofitting MFA to the Sharan Diesel Engine Technology
