Climate compressor, shaft blocked
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post02-01-2009, 0:22    Subject: Climate compressor, shaft blocked Quote
Good morning.
Golf 4 AC compressor:
Located centrally and rotating with the compressor shaft, just in front of the magnetic coupling, is a nut (M 8, size 14) that has become loose.
I've already energized the magnetic coupling and it engages, but I can't tighten the nut; it just spins the shaft along with it!
How can I tighten it without disassembling or taking anything apart? (How can I lock it in place?)
Who has a icon_idea.gif?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 13-07-2026, 19:46.
thom
Post02-01-2009, 12:49    Subject: Climate compressor, shaft blocked Quote
Impact wrench when you arrive.
Translated on 13-07-2026, 19:47.
Back to top Profile PM Email
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post02-01-2009, 13:25    Subject: Climate compressor, shaft blocked Quote
I've also considered using an impact wrench, but there isn't enough space.
Can the air conditioning compressor be disassembled to that extent without opening the system and pivoting it backward to create 15 cm of space?
Querstromkopf
Post02-01-2009, 17:32    Subject: Climate compressor, shaft blocked Quote
hi,
Here's an idea I have...
"Energize the magnetic coupling, then the compressor will be supported by the ribbed belt against the stationary motor. Then tighten the nut; the friction in the belt will definitely provide enough force for 30 Nm."
If you ask me, the wave on the toothing will be damaged, because they don't come loose for no reason icon_cool.gif.
Translated on 13-07-2026, 19:48.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post02-01-2009, 17:56    Subject: Climate compressor, shaft blocked Quote
If there used to be any interlocking parts, they are no longer connected.
You turn the nut to rotate the rotor (or shaft) inside the compressor, even though it is energized.
The lock nut also shows signs of corrosion (as the rear wheel sometimes appears rusty brown).
I'm also worried about the integrity of the compressor!
Translated on 13-07-2026, 19:49.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post13-01-2009, 9:57    Subject: Climate compressor, shaft blocked Quote
Preliminary conclusion:
Lima and carrier systems expanded.
Compressor loosely attached but still connected.
The mother was fastened with an impact wrench.
It slips slightly when the "M" clutch is open.
It hums quietly when it's powered on.
I also just installed a Lima freewheel.
Everything is much quieter now - test run successful.
Eventually, the compressor will need to be serviced, but for now, we're going to try and get through the summer.
Translated on 13-07-2026, 19:51.
No new posts Doku Golf 1J, Air conditioning compressor making noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Blocked Fuel Tank Return: Causes and Solutions. Diesel Engine Technology
No new posts Turbine Shaft Bearing: Design & Application Diesel Engine Technology
No new posts ESP Wave Alignment: Cylinder 1 Diesel Engine Technology
No new posts ESP Shaft: 0.1mm Play - Replacement? Diesel Engine Technology
