AFN: N75 valve (in VW technical jargon: pressure sensor/converter)
Go to page: 1, 2  Next
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post18-06-2007, 17:26    Subject: AFN: N75 valve (in VW technical jargon: pressure sensor/converter) Quote
Hi there,
At the AFN, there are two pressure converters (i.e., electrically controlled air valves) that are almost identical in design.
Once, the N75 valve, which supplies vacuum to the VTG turbocharger.
Then there's the N18 module, which controls the EGR valve.
Can the valve for the EGR control also be used as an N75?
The part numbers are different, but as far as I can tell, the only difference lies in the connector type of the electrical connection.
Is that correct?
Jens.
"Just to avoid any misunderstandings, I have an unused N18 module here that can be used to perform the function of the N75."
Marcus "Ar Gwenn": Für uns sind Leute arm, weil sie mit einem Eselskarren unterwegs sind, für sie sind wir arm, weil wir ein Leben lang dafür arbeiten und Geld verdienen müssen, um uns im Alter von wildfremden Leuten pflegen zu lassen.
Translated on 11-07-2026, 12:52.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post18-06-2007, 19:34    Subject: AFN: N75 valve (in VW technical jargon: pressure sensor/converter) Quote
They are reversed, but they function perfectly fine.
For VW/Audi (Skoda), it's available for 35 Euros, part number 1JO 906 627 A [N75]. It's the same as the one for VW Audi, which costs 88 Euros! icon_lol.gif
B.Eng (FH) u. KFZ Meister
Translated on 11-07-2026, 12:54.
dieter
Karma: +13 / -0   Thank you, like it!
Post19-06-2007, 11:29    Subject: AFN: N75 valve (in VW technical jargon: pressure sensor/converter) Quote
Hi Jens,
Otherwise, this part should also be available at automotive parts stores.
Pierburg 7.21903.75.0 - Electric-pneumatic pressure converter (EPC) for charge air pressure.
Greetings,
"Dieter"
T3 syncro 16 AFN
Translated on 11-07-2026, 12:55.
Jens 16syncro
Post19-06-2007, 22:02    Subject: AFN: N75 valve (in VW technical jargon: pressure sensor/converter) Quote
Bought a new N75, and it's working again.
I'll take the old one apart and examine it sometime.
Jens.
cksIT
Post21-06-2007, 11:20    Subject: AFN: N75 valve (in VW technical jargon: pressure sensor/converter) Quote
Did you get the one from the Golf (1j0), or the expensive one?
Translated on 11-07-2026, 12:56.
Jens 16syncro
Post21-06-2007, 15:21    Subject: AFN: N75 valve (in VW technical jargon: pressure sensor/converter) Quote
cksIT wrote:
Hast du jetzt das vom golf genommen? (1j0) oder das teure?
I bought it from a Volkswagen dealership because there aren't any SEAT dealerships nearby, and I was in a hurry.
I would have preferred to order directly from Pierburg, but that would have taken too long at this point.
I'm getting a high discount tier from Volkswagen, which makes it slightly less painful (though it's still an exorbitant price).
cksIT
Post21-06-2007, 15:56    Subject: AFN: N75 valve (in VW technical jargon: pressure sensor/converter) Quote
Golf is from VW icon_smile.gif.
And all dealers can order this part as soon as they have the part number.
I also get good percentages, but I prefer to apply them to the cheaper items icon_smile.gif.
Translated on 11-07-2026, 12:57.
Post17-01-2009, 20:22    Subject: AFN: N75 valve (in VW technical jargon: pressure sensor/converter) Quote
Steffarn wrote:
For VW/Audi (Skoda), it's available for 35 euros, part number 1JO 906 627 A [N75]. It's the same as the one for VW Audi, which costs 88 euros! icon_lol.gif
*warm up*
The strange LD (load dump) behavior of my partner's car, despite the easily adjustable VTG (variable turbine geometry), now also smells like a worn-out N75 valve.
So kommen bei 900 mbar Unterdruck am Eingang und einem 75% TV im Leerlauf (laut VSt-KF) nur ca. 500 mbar Unterdruck aus dem N75. Manchmal bricht der Volllast-LD laut LDA nach etwas zu langen Überschwingern von ca. 1,1 auf 0,5 bar ein . . . icon_confused.gif
The part number 1HO 906 627 A is installed, and Volkswagen now reportedly charges around €90 for it; the part number 1J0... is listed at €39.
Question:
Could they possibly differ in the type of electrical connection?
The Ibiza models equipped with the N18 and N75 connectors use the older style connector with the steel wire locking clip, while most other small connectors already have this fiddly plastic locking tab.
If I order the cheaper 1J0...N75 part, do I also need a newer cable connector at the same time?
Translated on 11-07-2026, 12:59.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post17-01-2009, 21:27    Subject: AFN: N75 valve (in VW technical jargon: pressure sensor/converter) Quote
The round connector also needs a matching plug because the pins are very thin and need to be water-resistant.
You might be able to find a round connector used from a defective wiring harness at your local dealer's parts department.
I have new square steel staples available in size 7.21 x 0.3.
7.21903.70, square shape, and 059 906.627 C (round connector), used, functional but without warranty.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 11-07-2026, 13:01.
Post17-01-2009, 21:29    Subject: AFN: N75 valve (in VW technical jargon: pressure sensor/converter) Quote
Hi Ulf,
I'm not entirely sure, but I also looked into this difference in growth at one point.
- The plugs are different.
- There are valves that have a mini-filter instead of the ATM hose (for the air filter or something), so they only have two hose connectors.
Jan might still be able to help out with the Ibiza ASV and take a look at it.
Translated on 11-07-2026, 13:02.
Jan6K
Avatar-Jan6K
Post17-01-2009, 23:11    Subject: AFN: N75 valve (in VW technical jargon: pressure sensor/converter) Quote
I can do that; I'll work on the car tomorrow, so it fits in well with my schedule icon_smile.gif.
It's very likely that I also have the version with steel brackets, because the car is only slightly younger than Ulf's.
"If I can access the part without disassembly, I can also check the part number; it's usually enough to just see if it's a Golf 3 (1H) or a Golf 4 (1J). The car itself is quite an interesting mix of Golf 3 compatible chassis components and Golf 4 drivetrain technology."
Jan.
1Z5 CFHF / AHB H4D
Translated on 11-07-2026, 13:04.
Octavia_4x4
Post18-01-2009, 14:03    Subject: AFN: N75 valve (in VW technical jargon: pressure sensor/converter) Quote
Ulf:
"If you need the connector housings, please find out the VW part number. Then I'll put a used connector plus 2 new crimp contacts and 2 wire sealing plugs into an envelope for you."
You only need a crimping tool for the connectors... VW is outrageous to charge so much for the connectors (€2.02), the repair cable with connectors (€1.56), and the two seals (€1.00). It's a rip-off.
If it's a connector housing, and I have some used ones in stock, you can have one for free from me.
Translated on 11-07-2026, 13:06.
Post18-01-2009, 15:25    Subject: AFN: N75 valve (in VW technical jargon: pressure sensor/converter) Quote
Ibiza1986 wrote:
Ulf:
If you need the connector housings, please find out the VW part number. Then I will put a used connector + 2 new crimp contacts + 2 wire sealing caps into an envelope for you...
Thank you. icon_biggrin.gif I may get back to you about this later.
Translated on 11-07-2026, 13:07.
Octavia_4x4
Post18-01-2009, 17:56    Subject: AFN: N75 valve (in VW technical jargon: pressure sensor/converter) Quote
Sure.
Since I'm a chronic collector of socket housings, I'm sure the right one will be there.
Are they all collected, carefully sorted, and pinned up, etc.?
Translated on 11-07-2026, 13:08.
Post18-01-2009, 19:41    Subject: AFN: N75 valve (in VW technical jargon: pressure sensor/converter) Quote
teileklaus wrote:
The round connector also needs a matching plug because the pins are very thin and must also be water-tight.
7.21903.70
square and 059 906.627 C (round connector) used, functional but without warranty. } So, according to the documentation, the part is likely related to the 1J0... The connector itself seems to be 1J0973722.
But I'll get the valve first – I might even have something suitable myself in my toolbox...
P.S.: We were unable to read any part numbers from the existing Ibi steel clamping sleeves; we only saw a small inscription that said "Germany." According to the records, this should be part number 37906240...
Translated on 11-07-2026, 13:09.
Jan6K
Avatar-Jan6K
Post18-01-2009, 20:30    Subject: AFN: N75 valve (in VW technical jargon: pressure sensor/converter) Quote
For completeness' sake: The ASV-Ibiza from 2001 also uses the parts with the steel bracket clips on the connectors. I didn't check the part number further because Ulf also has this version.
Jan.
1Z5 CFHF / AHB H4D
Translated on 11-07-2026, 13:11.
No new posts Pressure Transducers: Types & Applications Diesel Engine Technology
No new posts Pressure Transducer 1Z Diesel Engine Technology
This topic is locked, you cannot edit or reply. Pressure Sensor 1H0 vs. 1J0: Differences & Compatibility Diesel Engine Technology
No new posts Turbo Pressure Sensor: Only 5V? Diesel Engine Technology
