Auxiliary Heater VW T4 Fan Rear
doppelteglasur
Post31-01-2009, 20:30    Subject: Auxiliary Heater VW T4 Fan Rear Quote
A friend of mine owns a 2001 T4 van that came from the factory with a built-in auxiliary heater.
This air conditioning system only heats the interior via the front blower fan.
Is there a way to make the rear blower run?
Translated on 30-07-2026, 22:33.
michiglaser
2007 Audi A4 Avant
Post01-02-2009, 17:46    Subject: Auxiliary Heater VW T4 Fan Rear Quote
Does the bus have a Climatronic system or a manual heating control?
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 30-07-2026, 22:34.
doppelteglasur
Post01-02-2009, 18:25    Subject: Auxiliary Heater VW T4 Fan Rear Quote
Yes, it has Climatronic. They also installed a second battery so that the heating can run overnight.
scrdel
Karma: +4 / -2   Thank you, like it!
2002 Volkswagen Passat
Post01-02-2009, 23:00    Subject: Auxiliary Heater VW T4 Fan Rear Quote
The front climate control system is powered by 12V from the auxiliary heater via pin 1. If you extend this wire to the rear climate control panel and connect it to pin 1 there, the panel will power on and control the actuators accordingly.
Everything runs automatically with just a fan; you don't need to do anything else.
Is there a second fan motor for the rear as well? Does it need to be controlled via a relay, like the front one, in order to receive power from the auxiliary heater at 12V when the ignition is off?
That's what I think, at least... ?
Are there any dissenting opinions?
Sven.
Translated on 30-07-2026, 22:35.
doppelteglasur
Post01-02-2009, 23:09    Subject: Auxiliary Heater VW T4 Fan Rear Quote
Yes, it has a second fan on the back.
Does the rear control panel need to be powered?
I would be fine if only the second fan is running.
Translated on 30-07-2026, 22:36.
scrdel
Post01-02-2009, 23:29    Subject: Auxiliary Heater VW T4 Fan Rear Quote
It probably won't be very useful if only the fan is running; the air needs to escape somewhere. Therefore, you will also need to power the control unit, as it regulates the ventilation flaps.
Sven.
Translated on 30-07-2026, 22:37.
michiglaser
2007 Audi A4 Avant
Post01-02-2009, 23:48    Subject: Auxiliary Heater VW T4 Fan Rear Quote
The rear ventilation system in the T4 doesn't seem to have any flaps.
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
doppelteglasur
Post02-02-2009, 16:42    Subject: Auxiliary Heater VW T4 Fan Rear Quote
I couldn't find any servo motors either. Since the electric windshield wiper is working, it should be enough to just power the fan.
Translated on 30-07-2026, 22:38.
scrdel
Post02-02-2009, 21:16    Subject: Auxiliary Heater VW T4 Fan Rear Quote
Hello, if there are no dampers available, it should still work by simply activating the fan.
Greetings, Sven.
doppelteglasur
Post02-02-2009, 21:19    Subject: Auxiliary Heater VW T4 Fan Rear Quote
That's exactly what I'm concerned about. I wanted to know the best way to solve it. Ideally, someone has already done this and can give me some tips.
Post02-02-2009, 21:32    Subject: Auxiliary Heater VW T4 Fan Rear Quote
There's really everything available online regarding the T4... just take a look here; maybe you'll find something useful.
http://www.t4-wiki.de/wiki/Gebl%C3%A4se_V80_%28Frischluft_hinten%29
Translated on 30-07-2026, 22:39.
Post02-02-2009, 21:36    Subject: Auxiliary Heater VW T4 Fan Rear Quote
or there.
http://www.t4-wiki.de/wiki/Gebl%C3%A4se_V47_%28Warmluft%29
doppelteglasur
Post02-02-2009, 21:39    Subject: Auxiliary Heater VW T4 Fan Rear Quote
Thank you very much, Matthias. This is exactly what I was looking for!
Post02-02-2009, 22:01    Subject: Auxiliary Heater VW T4 Fan Rear Quote
"...and there's so much more... why isn't this available for the T5 I have here...? Oh well, I don't have time to tinker with it anyway... please feel sorry for me."
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post02-02-2009, 22:12    Subject: Auxiliary Heater VW T4 Fan Rear Quote
matthiasTDI96 wrote:
...and there's so much more...why isn't it available for the T5 I have here...? Oh well, I don't have time to tinker anyway...please feel sorry for me
because you have or will have much more serious problems with the T5, there's no time for tinkering. icon_twisted.gif
poor black cat icon_wink.gif regret
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 30-07-2026, 22:40.
Post03-02-2009, 7:19    Subject: Auxiliary Heater VW T4 Fan Rear Quote
Translated on 30-07-2026, 22:41.
No new posts Golf 1J: Rear Clicking Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Workshop action Polo MJ 2000, rear brake hose Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Repair: Rear Hatch Lock Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary Relay for Blower & AC Control in Parking He... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A4 Blower Problems: Common Issues & Fixes Diesel Engine Technology
No new posts Blower Relay J323 - Replacement & Parts On-Board Diagnostics (OBD)
No new posts 3B5: Troubleshooting and Common Issues On-Board Diagnostics (OBD)
