On January 25, 2009, the first chapter of this faithful companion's life came to an end. What was believed to be a piston failure was supposed to give our loyal friend a new heart and a little rejuvenation.
After starting the car in the morning, it didn't run smoothly. However, when parked in the evening, everything seemed fine.
After 200 meters, I stopped and checked the crankcase pressure by removing the oil filler cap. There was significant pressure there, which, along with blue smoke, is a good indicator of piston damage.
It's unbelievable that such an engine would give up at 530,006 km.
After disassembly and dismantling, there was a slight surprise. No damage was immediately apparent, and even the original head gasket appeared to be in good condition.
Pistons and engine components appear to be in excellent condition with no visible signs of wear, seemingly with only around 50,000 km (approximately 31,000 miles) on them.
"Running shoes with original soles and no scratches, all very clean except for minor leaks in the ESP (Electronic Stability Program) and signs of continuous use over the past 15 years."
A precise damage assessment will only be possible after further disassembly.
The reason for the disassembly was significant compression loss and the presence of compression pressure in the crankcase. Given the good overall condition, I'm almost speechless or at a loss for words.
Could such compression loss also be caused by faulty piston rings?
Why aren't there any scratches in the barrel liner?
I'll be disassembling it once I get my loaned engine stand back.
Best regards, efistho.
