Golf II 1.6D Timing Belt Replacement
Finger
Post01-02-2009, 21:13    Subject: Golf II 1.6D Timing Belt Replacement Quote
Hi.
Yesterday, I wanted to give my 'Postbomber' (Golf II, 1990, 1.6D) a new timing belt and help him stop having accidents. The new water pump wasn't a problem, but to remove the lower cover of the timing belt, you probably have to remove the pulley from the crankshaft *Annoying*.
So, basically, these 4 inner-facing screws and that big hex-head screw in the middle were just mocking me. In a state of shock, I first disassembled the device again.
Has anyone of you ever done this? I have a few questions...
What kind of screw is this, and what type of nut goes on it (outer diameter 21.5mm, the teeth are on the outside)? Does it have a left-hand or right-hand thread? In my opinion, it should have a left-hand thread. And how do you counter the crank shaft to loosen it? With which moment does one reattach it?
Or is it enough to just loosen the 4 Inbus screws? It didn't seem like that was the case. My two publications, 'Now I'm Doing It Myself,' are completely silent on this matter.
Can someone please help me?
BTW: It's about this model here: http://www.fingers-welt.de/gallerie/eigen/maschine/poel/poel.htm
Fingers
Karma: +575 / -0   Thank you, like it!
Post01-02-2009, 21:35    Subject: Golf II 1.6D Timing Belt Replacement Translating...
[Translating...]
Hallo!
Als ehemaliger Post-Autoschlosser kann ich Dir da helfen:
Mach die 4 Imbusschrauben ab, dann klappt das, besorge vorher aber 4 neue Schrauben.
Die innere Schraube kann bleiben, ausser, wenn Du den KW-Simmerring wechseln willst.
Spannrolle mit wechseln, der Zahnriemen wird mit Handgefühl gespannt.
Ich weiss nicht, nach welcher Methode Du das machst:
- Zahnriemen markieren, und die Markierungen auf den neuen Riemen übertragen und genauso wieder drauf, wie der alte war.
- oder halt das volle Programm, mit Einspritzpumpe abstecken, NW-Lineal und EP einstellen,
VDD-Satz erneuern. (Da gibt es jetzt so schöne Gummidichtungssätze)
BM
Avatar-BM
Post01-02-2009, 23:38    Subject: Golf II 1.6D Timing Belt Replacement Translating...
[Translating...]
Mit einer vernünftigen neuwertigen 1/2 Zoll Inbusnuß sollten die Schrauben eigentlich heil bleiben. Und - Vorsicht, bitte nicht deinen geliebten Heißkleber zum befestigen der Bauteile benutzten icon_wink.gif und spanne den Zahnriemen nicht zu stramm.
3B5 AJM
Finger
Post02-02-2009, 9:49    Subject: Thank you for the tips. Quote
Thank you for your quick responses. I'm going to get a really high-quality Inbusnuss.
Fingers
Karma: +786 / -0   Thank you, like it!
Post02-02-2009, 11:15    Subject: Golf II 1.6D Timing Belt Replacement Translating...
[Translating...]
... und 4 neue Inbusschrauben sind sinnvoll, aufgrund vom Alter könnten die nämlich schon ganz schön rostig sein und vom Aufdrehen wird der Innensechskant nicht besser. Die große Schraube/Mutter in der Mitte muss nicht ab.
Sollten sich die Innensechskantschrauben weigern, einfach Kopf abbohren und dann rausdrehen.
vwSchrauber
Karma: +42 / -0   Thank you, like it!
Post02-02-2009, 12:55    Subject: Golf II 1.6D Timing Belt Replacement Translating...
[Translating...]
Oder ein paar gefühlvolle Hammerschläge auf die angesteckte Innbusstecknuss. Nicht zu fest, denn sonst -könnte- das Zahnriemenritzel (Sintermetall) beschädigt werden.
Nach dem ZR- Wechsel den Förderbeginn kontrollieren, bzw. nach Gehör feststellen, ob er nun anders läuft.
Uli S.
Post02-02-2009, 15:15    Subject: Re: Golf II 1.6D Timing Belt Replacement Quote
Finger wrote:
To remove the lower belt cover, you probably need to remove the pulley from the crankshaft *Nerv*
What is this screw called
She has many names. Camshaft screw (like the eponymous syndrome http://dh5eah.toxisch.net/salatoel/kw_schraube/kw_schraube.html), trigger screw, killer screw.
Let it be, as long as it hasn't caused any trouble so far icon_rolleyes.gif, even though Sauger are usually less affected by this problem.
or, what type of nut does that belong on (outer diameter 21.5mm, the teeth are on the outside)?
19er 12-Zahn. A 19mm ring spanner also works, but only once the wedge pulley is removed.
right
And how do you counter the crankshaft to resolve the issue? With which moment do you re-tighten it?
by using a strong screwdriver to block the starter gear through the viewing hole in the clutch bell. Risky due to the risk of slipping, but it could work. Attaching with 90Nm + 90° (e.g., 19mm ring with a 1m pipe from the scaffolding inserted).
But all of this is just for completeness. Loosen them and simply remove the 4 M8 screws, as the others have already said. If the pulley is stuck and won't come off, use a small hammer to alternately tap it. A little bit of creeping oil also helps.
Best regards, Uli
Golf2 GTD AAZ, LLK, CYP
Bus T3 JX
2x Golf2 GTD/SB
97er Golf 3 AFN, 70-100% Pöl
97er Golf 3 Variant AFN
96er Passat 35i AFN
BM
Avatar-BM
Post02-02-2009, 16:26    Subject: Golf II 1.6D Timing Belt Replacement Translating...
[Translating...]
Bevor man die Bohrmaschine ansetzt, hilft meistens eine Vielzahnnuß (die man für Antriebswellen benötigt), mit leichtem Hammer in den Sechskant treiben und lösen -- funktioniert in 99% aller Fälle.
PS.: Ich denke nicht, daß er die Schrauben erneuert. Das widerspricht seinem Natural icon_wink.gif .
3B5 AJM
vwSchrauber
Post02-02-2009, 16:40    Subject: Golf II 1.6D Timing Belt Replacement Translating...
[Translating...]
von nem Helfer mit nem kräftigen Schraubenzieher durchs Guckloch im der Kupplungsglocke die Anlasserverzahnung blockieren lassen. Heikel wegen Abrutschgefahr, aber kann klappen. Anziehen mit 90Nm + 90° (z.B. 19er Ring mit drübergestecktem 1m-Rohr vom Baugerüst).
Das ist die zivilisierte Methode.
Ohne Helfer gehts aber auch:
Ich mach das immer mit Gewinde und Bund einölen, Planreibfläche am Ritzel trocken. Dann bei eingelegtem Gang die 90Nm. Die 90° erfolgen per Druckluftschlagschrauber@14Bar icon_twisted.gif icon_twisted.gif icon_twisted.gif
Treibst du den Vielzahn gewaltsam in die rundgelutschte Innbusausnehmung?
Naja - spätestens beim nächsten Riemenwechsel wird er sie dann erneuern icon_lol.gif
Post02-02-2009, 16:42    Subject: Golf II 1.6D Timing Belt Replacement Translating...
[Translating...]
Oder er baut was völlig neues daran....beneidenswerter Erfindergeist mit Hang zur Selbstzerstörung. Respektabele Leistungen erzielt, habe schon einen schönen Abend beim Studium der HP gehabt, weiter so!!!
Also ich hab die 4 Schrauben bisher mit einem gescheiten Imbus, vorher leichten Schlägen auf den Kopf immer rausbekommen. Habe auch jedesmal neie Schrauben eingedreht, dei kosten nichts....lohnt aber in der tat nur wenn man da nochmal dran muss, wenn der Lebenszyklus des Fahrzeugs bis zur nächsten Demontage eh vorbei ist.....
BM
Avatar-BM
Post02-02-2009, 20:01    Subject: Golf II 1.6D Timing Belt Replacement Translating...
[Translating...]
Nicht wirklich. Ich nehme meistens einen 200gr Hammer dazu. Bis auf die Kanten passt sie fast von alleine.
Jo, ich habe auch schon einen schönen Abend mit seiner HP verbracht - Faszinierend.
Eins muß man ihm lassen -- er weiß genau was er tut. Weiter so Finger.
3B5 AJM
Finger
Post09-02-2009, 11:32    Subject: Okay, no problem. Quote
Okay, the tank is running again. It seems the spool was actually too cheap and didn't fit properly, but that's something that can be fixed. I had to drill out most of the screws, including those from that stupid plastic cap. So rotten new_cry.gif(((
But again, something else. Somehow, you always have one ear on the engine. I have the feeling that something is rattling in the valve mechanism, even when the machine is warm. *Seuzf* The temperature gauge has also just gone out. So, the outdated electrical system is definitely one of the main problems here. But let's get back to the main point.
Now, Uncle Korf says: Check the hydraulic lifters. To do this, warm up the engine in the bucket, then wait in neutral until the cooling fan starts, and then run it at 2500 RPM for another 2 minutes (and so on and so forth). Is this really necessary? I can still see the oil is as hot as possible, but then I can't just briefly accelerate my sports truck over the highway and then risk taking a look under the hood? Would at least be a bit more friendly towards the neighbors.
Fingers
BM
Avatar-BM
Post09-02-2009, 14:47    Subject: Golf II 1.6D Timing Belt Replacement Translating...
[Translating...]
Na ja, je nach Geräusch und Defekts eines Hydros kann es dir passieren, daß dieser sich nach Autobahnfahrt wieder soweit vollgepumpt hat, so daß er sich überhaupt nicht mehr zuverlässig lokalisieren lässt, was auch sonst schon ein Lotteriespiel ist. Nicht selten ist es so, daß ein vermeintlich defekter Hydro nicht wirklich der Geräuschverursacher ist, sondern ein anderer. Und da zum auswechseln die NW raus muß, wechselt man normaler weise alle aus, außer man hat viel Langeweile.
Hast du schon mal über die Abwrackprämie für das Moped nachgedacht icon_question.gif
Wenn du ihn vorher ausschlachtest, könntest du den Motor versuchsweise noch zu einer Wärmekopplungsanlage umbauen und mit der Heizkostenersparnis ein neues Moped finanzieren. icon_wink.gif
3B5 AJM
Uli S.
Post09-02-2009, 14:47    Subject: Re: Okay, done on the machine. Quote
Finger wrote:
But, one more thing. Somehow, you always have one ear on the engine. I have the feeling that there's something rattling in the valve train, even when the machine is warm. *Seuzf* The temperature gauge has also just gone out. So, the faulty electrical system is definitely one of the main problems here.
I would just let it clatter...
Yes, the electrical issue is a nuisance. One would think that, especially older mechanical diesel engines, wouldn't have any problems with it icon_rolleyes.gif. A lot of it comes from the rainwater that gets through the windshield during rain and goes through the central electrical system before finally dripping onto the driver's left foot. My 2er almost got completely fried because of this, apparently it wasn't the first icon_evil.gif. New windshield and sealing, since then it's okay. But the temperature gauge still doesn't work (wiring is melted). I just bought a 120° VDO gauge.
Now Uncle Korf says: Check the hydraulic lifters. To do this, warm up the engine, then let it idle until the cooling fan comes on, and then run it at 2500 RPM for another 2 minutes (and so on and so forth). Is this really necessary? I can still see the oil is as hot as possible, but then I can't just briefly accelerate my sports truck over the highway and then risk taking a look under the hood? Would at least be a bit more friendly towards the neighbors.
yes, I would do it that way. Even finished hydros make noise at normal operating temperatures, not just at 130°C oil temperature.
Best regards, Uli
Bus T3 JX
2x Golf2 GTD/SB
96er Passat 35i AFN
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Zahnriemenwechsel Audi A6 4F, BRE Motor 2.0 TDI PD Troubleshooting & Guides
No new posts Zahnriemenwechsel PD Motor Quereinbau Troubleshooting & Guides
No new posts V6 TDI Timing Belt Replacement, AFB Diesel Engine Technology
No new posts Timing belt replacement AJM Diesel Engine Technology
No new posts Zahnriemenwechsel bei AVF Diesel Engine Technology
No new posts Timing Belt Replacement 1 Diesel Engine Technology
