mechanics77
23-11-2009, 21:44 Subject: Polo 9N3 1.4 PD DPF: Engine Won't Start |
Hey everyone!!!
I have a question regarding the evaluation of measured value blocks for the 1.4L PD/DPF (BMS) system...
Perhaps you can help me. This is a driving school car that's used all day, and it's mostly driven at low RPMs! Mileage: 170,000 km.
Problem: Vehicle has no power.
The engine is running unevenly, and it's producing a lot of black smoke, especially under load.
High consumption.
Lambda, maximum value, fully saturated.
AGR is immediately and fully activated (100%) under load.
Turbo, intercooler, and valve timing are all okay.
I have the measurement data for both idle and load conditions.
I removed and cleaned the AGR valve (it was heavily carbonized, and it had already been replaced a year and 70,000 km ago due to carbon buildup).
Exhaust Gas Recirculation (EGR) valve diagnosis performed while the component was removed: OK. Reinstalled the valve, but the problem persists.
My question now is, who can analyze MWB data and identify correlations... or has anyone encountered a similar case before?
The fact is, it's constantly running at full throttle... I suspect it's either the EGR valve or the mass airflow sensor... but I don't want to just guess...
Translated on 20-09-2026, 18:56.
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2406 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
23-11-2009, 22:26 Subject: Polo 9N3 1.4 PD DPF: Engine Won't Start |
Tip:
- Check the charge air cooler for leaks.
- Post measurement data.
- Please adhere to the forum rules.
Guste.
Translated on 20-09-2026, 18:58.
Profile PM Garage |
DieselBär30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3560 Karma: +101 / -0 Location: München & Passau
23-11-2009, 22:32 Subject: Polo 9N3 1.4 PD DPF: Engine Won't Start |
Hello Gauls!
Here's a preliminary note: In this post, we don't expect every sentence to be confirmed with "3x Return" or, alternatively, to end with 3-4 exclamation or question marks. *smart-aleck*
If you already have those log files, why don't you upload them directly to our "Upload" section here?
"Lambda at the maximum emission limit" is displayed in the measured values (completely outrageous, seriously!).
In the crystal ball, I'm excluding your description of "100% AGR at load." I think you might be confusing the control ratios of the valves for AGR (Abgasrückführung) and VTG (Variable Turbine Geometry)?
Alternatively (seriously, this is crazy!), someone might have been working on it before, and they incorrectly installed the hoses or electrical connections of the aforementioned valves  .
Okay, please upload the logs you mentioned, so we can better assist you.
(totally awesome, dude!) Greetings from Munich!
EDIT: *zefix* Guste was faster - again today! ...am I getting old? *g*
Translated on 20-09-2026, 19:00.
mechanics77
23-11-2009, 23:31 Subject: Polo 9N3 1.4 PD DPF: Engine Won't Start |
1 error detected.
08598 P2196 000
Lambda sensor 1, bank 1 - mixture too rich.
sporadically
Environmental conditions:
Default values:
Date.
Time.
Mileage.
0167280
Priority.
2
Error frequency.
1.
Lost counter.
Measurement values:
Value 1.
1990 /min
Value 2.
84 km/h
Value 3.
69
Value: 4
39.6 °C
Value: 5
1040 mbar
Value: 6
0.584 V
Value: 7
0.03
Measurement.
Result.
Set point.
Engine speed.
900 per minute.
790 - 1000 revolutions per minute.
Injection amount.
4.7 mg/H
3 - 9 mg/dose.
Funding duration (target).
6.8 kW
3 - 9 °KW
Coolant temperature.
63.9 °C
> 75 °C
Engine speed.
880 /min
Throttle position sensor.
0.0%
> 0%
Operating states.
0 01 0
00000 - 11111
63.9 °C
> 75 °C
Engine speed.
880 /min
Exhaust gas recirculation (EGR) should be...
250 mg/hour.
220 - 350 mg/dose.
Air mass is...
555 mg/H
220 - 350 mg/dose.
Exhaust gas recirculation duty cycle.
100%
20 - 90%
Engine speed.
900 per minute.
Start date of funding: To be determined.
2.5° v.OT
-4.0 to -2.0 °KW
7.2 kW
3 - 9 °KW
Rotation angle.
-2.3 °KW
-6 - +6 °KW
Engine speed.
880 /min
810 - 1000 revolutions per minute.
Start Quantity
12.6 mg/H
7 - 19 mg/dose.
Initial synchronization.
48
000 - 128
63.9 °C
> 75 °C
Driving speed.
0 km/h
0 - 300 km/h
Switch positions.
00001100
00000000 - 11111111
0 km/h
> 0.0%
FGR status not applicable to vehicles carrying ADR goods.
00000010
00000000 - 11111111
Air mass is...
550 mg/hour.
260 - 350 mg per injection.
Atmospheric pressure.
989 millibars.
900 - 1100 millibars.
Boost pressure is...
1009 millibars.
900 - 1150 millibars.
0.0%
> 0.0%
Engine speed.
900 per minute.
Target boost pressure.
1091 millibars.
1009 millibars.
Valve lift ratio, boost pressure.
79%
40 - 90%
Throttle valve control, fuel injection quantity, cylinder 1.
0.05 mg/H
-2.8 to -2.8 mg/dose
Throttle valve control, fuel injection quantity, cylinder 2.
-0.24 mg/H
Throttle valve control, fuel injection quantity, cylinder 3.
0.14 mg/H
Throttle valve control, fuel injection quantity, cylinder 4.
Solenoid valve for cylinder 1, used for traffic control.
0
< 00
"Solenoid valve for cylinder 2, used for traffic control."
0
< 00
"Solenoid valve for cylinder 3, used for holding pressure."
0
< 00
"Solenoid valve for cylinder 4, used for traffic control."
< 00
Solenoid valve switching time deviation, cylinder 1.
-38
-100 - 100
Solenoid valve switching time deviation, cylinder 2.
-40
-100 - 100
Solenoid valve, switching time deviation, cylinder 3.
-43
-100 - 100
Solenoid valve, timing deviation, cylinder 4.
-100 - 100
Pedal position sensor voltage 1 at full depression.
0.760 V
3,800 - 4,940 V
Pedal position sensor voltage 2 at full depression.
0.380 V
1.90 - 2.58 V
Sensor 1 for exhaust gas temperature, Bank 1 - G235.
306.0 °C
0 - 790 °C
Exhaust temperature in the particulate filter (simulated).
270.0 °C
0 - 600 °C
Loading coefficient.
11%
< 45%
Lambda value.
2.69
Temperature before the turbocharger.
294.0 °C
Temperature before the diesel particulate filter.
282.0 °C
Temperature after diesel particulate filter.
246.0 °C
Functional test.
Translated on 20-09-2026, 19:13.
matthiasTDI96 Profi-Schrauber
24-11-2009, 9:24 Subject: Polo 9N3 1.4 PD DPF: Engine Won't Start |
Hello, please don't make the posts so long.
Check for leaks in the LD line.
Translated on 20-09-2026, 19:25.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
24-11-2009, 9:25 Subject: Polo 9N3 1.4 PD DPF: Engine Won't Start |
Quote: | Engine speed.
880 per minute.
790 - 1000 revolutions per minute (RPM).
Air mass.
555 mg/H |
Either a counterfeit LMM (Mass Air Flow sensor) is installed (available with a Bosch logo on certain online marketplaces for scammers and those who want to be), or the air being measured is being leaked somewhere before the engine, causing a significant amount of noise.
At idle, without the EGR system, an air mass of approximately 440-480 mg/stroke is expected. If the part is completely clogged, it will likely be closer to 440 mg/stroke.
It's questionable whether the injection quantity at partial load is actually limited by the air mass in this component. Please post the VAG part number of the engine control unit.
However, the exhaust gas content is definitely too high and can already cause soot formation.
Translated on 20-09-2026, 19:27.
Profile PM WWW Garage |
mechanics77
24-11-2009, 18:54 Subject: Polo 9N3 1.4 PD DPF: Engine Won't Start |
Sorry about the long post!!!!
I've made some progress now!
- Intercooler system in good condition.
- Mass airflow sensor (original new part)
- Cross-exchange without modification.
-AGR valve is working.
DPF loading level: 43%, regenerated to 0% without issues. After another 10 km of constant driving in 5th gear at 3000 RPM, the loading level was already back up to 19%. Subsequently, while maintaining the same load, I observed that the lambda value was fluctuating between 2.0 and 2.7, simultaneously with the fuel injection quantity and injection duration being at their upper limits!
My conclusion is that it's possible that the injection time is extended to compensate for a lack of fuel or a pressure loss.
Power consumption of the pre-pump: 6A... OK.
Fuel pressure tandem pump, idling pressure: 4.5 bar, fixed.
Internal leak test of the pump using a test pressure of 1 bar (return closed) for 5 minutes - OK.
Fuel pressure at 3000 RPM without load is 7.2 bar, fluctuating by 0.5 bar. This value suggests that either the tandem pump is malfunctioning or the seals of the common rail injectors are faulty.
I plan to swap the tandem pump tomorrow, and if necessary, I will ultrasonically clean the PD elements and reseal them.
What do you think of my theory? Unfortunately, I don't have any new measurement data available.
Translated on 20-09-2026, 19:30.
Steffen W Profi-Schrauber
Joined: 07/05/2008 Posts: 1276 Karma: +104 / -0 Location: Altenburg
25-11-2009, 5:38 Subject: Polo 9N3 1.4 PD DPF: Engine Won't Start |
What happens if you block the return flow during a pressure measurement? Will the needle jump?
With what do you actually measure the fuel pressure? I used to have a pressure gauge that would also fluctuate a lot, especially at high RPMs. Eventually, I bought one filled with glycerin, and it got much better. I just want to say that this kind of problem can sometimes be caused by the gauge itself before you start replacing injectors.
Apart from the slight vibration, the pressure is actually quite good. MWB 23 also shows something similar.
Passat Variant BGW 2005
Translated on 20-09-2026, 19:32.
mechanics77
25-11-2009, 21:15 Subject: Polo 9N3 1.4 PD DPF: Engine Won't Start |
Error found... purely mechanical!
I can and want to post, but I don't want to do it publicly!!!!  .....6000 euros of damage.
Translated on 20-09-2026, 19:33.
25-11-2009, 21:40 Subject: Polo 9N3 1.4 PD DPF: Engine Won't Start |
mechanics77 wrote: | ...I can and want to post, but I don't want to do that publicly!!!! ... |
It's a shame, as this won't help other people seeking assistance. It would be nice to know what might cause something like that.
Profile PM Garage |
mechanics77
25-11-2009, 22:45 Subject: Polo 9N3 1.4 PD DPF: Engine Won't Start |
Okay... externally, there is information suggesting that, due to quality issues, some 1.9L PD engines may experience significant camshaft wear, leading to cracks or breakage of the hydraulic lifters. Furthermore, worn camshafts can extend the injection time. In these cases, the camshaft and hydraulic lifters need to be replaced. This often occurs in taxis, driving school vehicles, or vehicles driven frequently in short-distance traffic.
Internally, all PD (Pumpe-Düse) vehicles are affected, ranging from the 3B 1.9L to the 1J, 3C, 1T, and up to the 9N 1.4L engines.
In my specific case, it's a 9N-1.4L PD model from 2008 with 160,000 km. The camshaft is severely worn, the hydraulic lifters are broken, and there are signs of wear on the ball joint connecting the PDE to the adjustment screw. This has damaged the DPF (due to oil contamination), the EGR valve is clogged with carbon deposits, and there are turbocharger particles from the broken lifter. The guide in the cylinder head is also damaged due to the broken lifter.
Result: Replace the cylinder head with camshaft, DPF, and turbo... Clean the EGR... and this after two and a half years and 160,000 km.
Translated on 20-09-2026, 19:35.
25-11-2009, 22:50 Subject: Polo 9N3 1.4 PD DPF: Engine Won't Start |
Thank you for the information, even though it was late.
Translated on 20-09-2026, 19:37.
Profile PM Garage |
mechanics77
25-11-2009, 22:53 Subject: Polo 9N3 1.4 PD DPF: Engine Won't Start |
Hmmm, so far I'm at €6300... after two and a half years...
26-11-2009, 5:44 Subject: Polo 9N3 1.4 PD DPF: Engine Won't Start |
Translating... |
2024 Dacia Duster blue dci 115 |
26-11-2009, 7:46 Subject: Polo 9N3 1.4 PD DPF: Engine Won't Start |
What does your price include?
Why are you hesitant to express your opinion when you're going to pay for it anyway? What kind of oil was used? I've seen several 1.9 engines with camshafts that had significantly more than double the mileage and still looked good. Surely, even a driving school car idles for hours, and you only make money when the car is moving, right?
Translated on 20-09-2026, 19:38.
mechanics77
26-11-2009, 21:29 Subject: Polo 9N3 1.4 PD DPF: Engine Won't Start |
Cylinder head damaged by a broken hydraulic lifter in its bore.
Clogged diesel particulate filter and a stuck EGR valve due to a constantly rich fuel mixture!
Soot accumulation, approximately 1 cm thick.
Turbocharger damage cannot be ruled out due to the broken hydraulic lifter, especially considering the 2-year warranty on this repair!
Translated on 20-09-2026, 19:39.
