Headlight Adjustment Repair: How To Fix?
luiggi
Post26-02-2009, 18:27    Subject: Headlight Adjustment Repair: How To Fix? Quote
"I repeatedly experience issues with the headlight range adjustment in my A6 2.5 TDI, manufactured in 2002, especially when it's wet. The warning light appears briefly on the dashboard, and the error memory indicates a short circuit to ground for the front and rear adjustment motors, occurring sporadically. All the components are in good condition. The problem definitely originates from the connector of the sensors on the axles, as it's always wet inside the connectors. Since the connectors have a specific shape, I need to obtain original ones. However, I'm unsure about the exact procedure and what parts I need. Most importantly, do I need a special crimping tool or anything else? (Perhaps someone could briefly list the parts I need.)"
Translated on 13-09-2026, 4:27.
schrauber84
Karma: +1 / -1   Thank you, like it!
Post26-02-2009, 20:51    Subject: Headlight Adjustment Repair: How To Fix? Quote
Hi, you'll need the respective connector housing and the cable puller to get the cables out of the housing without damaging them. That's pretty much all there is to it.
Translated on 13-09-2026, 4:28.
luiggi
Post26-02-2009, 21:23    Subject: Headlight Adjustment Repair: How To Fix? Quote
I'm planning to buy a set of unlocking tools. Does anyone know a good place to get one? Maybe a set that works for all VW and Audi vehicles? Thanks.
Translated on 13-09-2026, 4:29.
Post27-02-2009, 0:50    Subject: Headlight Adjustment Repair: How To Fix? Quote
A very thin screwdriver that fits through will work just as well!
No new posts Halogen lamp adjustment, Headlight alignment Technical Articles
No new posts Automatic Headlight Leveling VW Touran 1T Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Headlight Leveling: Automatic Adjustment Transmission, Chassis, Body & Interior
No new posts Audi A6 C6 Headlight Leveling System Electrical Systems, Vehicle Electronics, Multimedia
No new posts Headlight leveling error code 01538 On-Board Diagnostics (OBD)
