Audi TT: Can't code central locking control unit. Help
Tobi76
Post05-03-2009, 20:40    Subject: Audi TT: Can't code central locking control unit. Help Quote
Hello.
I'm currently experiencing the following problem with a 1999 Audi TT:
The safe could no longer be opened using the remote controls.
The friendly technician then replaced the batteries and tried to reprogram the keys. This didn't work with the great tester, and they wanted to install a new control unit right away.
It turned out to be too expensive, and then they asked me for help.
Then I tried to program the keys using VAG-Com, but that didn't work either.
The error memory was empty except for one error related to the interior monitoring system.
I noticed that in measurement block 6, four keys are displayed, which is quite strange.
The control unit is coded with the value 000000.
When I tried to recode the REP/instruction, it didn't store the new value I entered, but instead saved something completely different. So, it didn't store the value I actually typed in.
I then, as a test, deleted the learned keys (locked 5 times).
The manual pairing process worked. Both keys are functioning correctly.
Unfortunately, due to my modification, the car has forgotten how to blink its lights when opening and closing. Otherwise, everything is working fine.
Does anyone have a tip for me?
Best regards.
Tobi.
Translated on 28-09-2026, 9:10.
No new posts Doku A3 8L, Airbag STG error cannot be cleared Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The Electric Car - Why It Isn't Taking Off Technical Articles
No new posts A4 Doku: Engine Control Not Connecting to WFS. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Help, I can't adjust my immobilizer On-Board Diagnostics (OBD)
No new posts Audi A6 4F Allroad: ESP cannot be deactivated Electrical Systems, Vehicle Electronics, Multimedia
No new posts Brake Control Module Coding Help On-Board Diagnostics (OBD)
No new posts A6 4F ignition won't turn on Electrical Systems, Vehicle Electronics, Multimedia
