Injector Replacement at AEL
selbstschrauber
Post29-05-2009, 13:42    Subject: Injector Replacement at AEL Quote
Hello everyone!
I plan to replace the injectors on my C4, manufactured in 1995, with 140 horsepower, and with 200,000 km on the odometer.
However, about half a year ago, I replaced the nozzle with the needle-actuator alone, because it was unfortunately defective and kept jamming! I can no longer afford the others icon_sad.gif
Now I'm faced with the dilemma of choosing!! Is it more sensible to incorporate larger ones, or should I stick with the new one with the needle guide and just replace the remaining 4?
Best regards, Hannes
Post29-05-2009, 14:01    Subject: Re: Injector Replacement on AEL Quote
selbstschrauber wrote:
Is it sensible to incorporate larger ones
If you might want to upgrade to more performance later on, yes. If you want to leave it as is, then it's pointless.
selbstschrauber
Post29-05-2009, 21:28    Subject: Injector Replacement at AEL Quote
Does 'more performance' refer to software tuning or upgrading to a larger turbo...?
Post29-05-2009, 23:50    Subject: Injector Replacement at AEL Quote
Upon conversion to a large turbo. So, for 30 more horsepower, you don't need any other nozzles yet.
selbstschrauber
Post30-05-2009, 14:24    Subject: Injector Replacement at AEL Quote
So, ich kann den mit dem Needle-driver einfach so lassen, wie er ist, und die anderen 4 mit diesen Düsen:
http://shop.dieselschrauber.de/product_info.php/cPath/36/products_id/77
repair??? Or is it not safe to know which size the original has in relation to the needle?
Post30-05-2009, 14:35    Subject: Injector Replacement at AEL Quote
I don't know what size AEL originally used. But I don't think they were 216s. Just use the search function. You'll figure out what's installed.
No new posts Einspritzdüsentausch: Tuning ohne elektronische Eingriffe Technical Articles
No new posts Timing belt replacement for 1.9l PD TDI engine. Troubleshooting & Guides
No new posts What is the synchronization angle in TDI? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Catastrophic failure after replacing the fuel injectors (... Diesel Engine Technology
No new posts Komischen Klackern Nach Einspritzdüsentausch! Diesel Engine Technology
This topic is locked, you cannot edit or reply. Nach Einspritzdüsentausch Ruckeln, Leistungsverlust, Nageln Diesel Engine Technology
No new posts Komisches Blubbern beim abstellen des Motors beim Golf 4 TDI Diesel Engine Technology
