Auxiliary Heater for VW Polo 9N3 1.9 TDI
Klausel
Post08-11-2010, 22:21    Subject: Auxiliary Heater for VW Polo 9N3 1.9 TDI Quote
Polo 9N3, manufactured in 2006, with Climatronic air conditioning, AXR engine, 1.9 liters.
Retrofitting can be challenging.
There is neither a retrofit kit available from Webasto nor from Eberspächer for...
only for the 1.4L engine.
Did anyone (or a contracted company) manage to do it after all?
Perhaps it's located on the lower left front, near where the large windshield washer fluid reservoir is.
(he would have to give in to the little one and get rid of SRA).
I am grateful for any suggestions.
Best regards, Klaus.
Polo 6R, TSI 110 PS
Translated on 02-08-2026, 11:10.
michiglaser
2007 Audi A4 Avant
Post08-11-2010, 22:46    Subject: Auxiliary Heater for VW Polo 9N3 1.9 TDI Quote
Unfortunately, I don't know anything about the playing field conditions for polo.
However, it would certainly be necessary to relocate the battery to the trunk in order to install the heating device where the battery currently is.
I came across a forum thread on Motortalk via Google. The thread is titled "Auxiliary heater for 1.9 TDI (100 hp)". In that thread, someone placed the heater in front of the engine, at the top of the engine compartment icon_eek.gif.
I have the same problem with my Audi, there's no space for a heater icon_sad.gif .
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 02-08-2026, 11:12.
Klausel
Post08-11-2010, 23:08    Subject: Auxiliary Heater for VW Polo 9N3 1.9 TDI Quote
Thank you. I've already seen this thread, but...
It probably isn't possible to integrate the AXR with Climatronic without major modifications.
Polo 6R, TSI 110 PS
Translated on 02-08-2026, 11:13.
michiglaser
2007 Audi A4 Avant
Post09-11-2010, 21:01    Subject: Auxiliary Heater for VW Polo 9N3 1.9 TDI Quote
It's hard to believe that an installation might not be possible without any issues.
Have you ever looked into which heating device, whether an auxiliary heater or a standalone heater, from either Eberspächer or Webasto is the smallest?
My research on the topic so far:
Thermo Top E: Dimensions 214 x 106 x 168.
Hydronic 4 S, dimensions: 220 x 86 x 101.5.
as well as the Hydronic II auxiliary heater, see picture. However, there are no dimensions provided for it... " color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusätzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema für andere Leser nutzlos!
/2hf0z0z.jpg" target="_blank" class="postlink" rel="nofollow">http://i51.
/2hf0z0z.jpg
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 02-08-2026, 11:14.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post15-11-2010, 21:35    Subject: Auxiliary Heater for VW Polo 9N3 1.9 TDI Quote
I have installed every auxiliary heater so far using the universal installation kit.
You will only need the fuel dispenser attachment.
Often, a metal bracket needs to be fabricated.
The auxiliary heater is best placed in the left wheel well.
And it has to be standing up. The SH doesn't do that.
Then, locate the pin for the auxiliary heater within the climate control system and, if available, the pin for the interior monitoring system.
Translated on 02-08-2026, 11:16.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post15-11-2010, 21:58    Subject: Auxiliary Heater for VW Polo 9N3 1.9 TDI Quote
Could the defrosting system be starting up because the auxiliary heater is running and circulating air inside the vehicle?
Translated on 02-08-2026, 11:17.
Tagessuppe
Post15-11-2010, 22:03    Subject: Auxiliary Heater for VW Polo 9N3 1.9 TDI Quote
Exactly that is happening.
By controlling the system, the sensitivity of the water quality sensor is reduced.
klahaui
Avatar-klahaui
Post15-11-2010, 22:18    Subject: Auxiliary Heater for VW Polo 9N3 1.9 TDI Quote
But is it really due to the blown air?
Is the airflow strong enough for the DWA to notice?
I'd like to try that out, but I don't have a drone with an internal monitoring system.
Translated on 02-08-2026, 11:18.
Tagessuppe
Post15-11-2010, 22:32    Subject: Auxiliary Heater for VW Polo 9N3 1.9 TDI Quote
Leaving the windows open in a car with an alarm system is enough to trigger it.
When the wind blows, she sets off.
michiglaser
2007 Audi A4 Avant
Post15-11-2010, 23:29    Subject: Auxiliary Heater for VW Polo 9N3 1.9 TDI Quote
I have to report something completely different about our T4.
The bus is equipped with an alarm system that includes ultrasonic interior monitoring, manufactured by VW SCS.
Neither the air heater that warms the passenger compartment nor the auxiliary heater (which blows air through the normal vents at the front) triggers the alarm system.
However, if you insert just 10 centimeters of your hand through a slightly open window, the alarm will trigger.
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 02-08-2026, 11:19.
Tagessuppe
Post15-11-2010, 23:49    Subject: Auxiliary Heater for VW Polo 9N3 1.9 TDI Quote
Both the A3 from 1997 and the Allroad from 2001 have a vehicle security system (DWA).
After 10 minutes with the window open = alarm.
Even in light winds.
Translated on 02-08-2026, 11:20.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post22-11-2010, 8:13    Subject: Auxiliary Heater for VW Polo 9N3 1.9 TDI Quote
Greetings Klaus
That's not entirely correct. The vehicle-specific installation kit for the Polo 9N with 74 and 96 kW PD engines is called Eberspächer 24 8317 00 00 00. This includes the mounting bracket for the heater unit. The additional kit for vehicles with Climatronic control is called Eberspächer 24 8098 00 00 00. There is also an installation guide from Eberspächer specifically for this Polo model.
Sure, here's the translation:
"Just a small tip:"
Until November 30th, the heating manufacturer is running a promotion called "Golden Autumn." They are offering a package that includes a heater, a special installation kit, a wireless remote control (Easy Start R+), and the installation manual for your Polo, all at significant savings. Whether you can order directly from them or if your dealer will pass on the offer depends on their specific policies.
Passat Variant BGW 2005
Translated on 02-08-2026, 11:22.
Jan03
2010 Volkswagen Polo
Post30-01-2011, 19:21    Subject: Auxiliary Heater for VW Polo 9N3 1.9 TDI Quote
There's also an installation guide from Webasto for the TT-C heater in the Fabia (which is largely identical to the 9N). However, I don't think any workshop would attempt this, as it's quite a risky undertaking because the heater needs to be mounted at an angle behind the engine, against the firewall. This requires drilling holes in the firewall and temporarily bending the oil line for the turbocharger.
I have a Webasto TT-V installed in my Fabia. It's the only one that fits properly, and it's located right at the front, in front of the radiator (and air conditioning condenser), directly behind the bumper reinforcement. The TT-C is too large for that location. It works perfectly, although the unit sounds like a jet fighter when running at full power.
A disadvantage of the TT-V is that it unfortunately requires significantly more fuel than the older TT-C/E/Z models, while providing almost the same heating output. Even though Webasto doesn't mention this in the data sheet icon_mad.gif.
Furthermore, it's not always easy to get the TT-V into the correct gear icon_confused.gif when using it in vehicles for which it wasn't originally designed.
/Jan
Translated on 02-08-2026, 11:25.
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Standheizung Einbau: D5WSC mit Easystart R+ Installation Troubleshooting & Guides
No new posts Auxiliary Heater for V6 TDI Engine Diesel Engine Technology
No new posts Standheizung??? Diesel Engine Technology
No new posts Heated Seats Audi A6 2.5 TDI V6 Diesel Engine Technology
No new posts Defective Heater: Troubleshooting & Repair Transmission, Chassis, Body & Interior
