SDI vs. TDI Fuel Injector Pump: Differences
35i-299
2004 Volkswagen Passat Consumption
Post26-03-2009, 11:38    Subject: SDI vs. TDI Fuel Injector Pump: Differences Quote
Hi there...
Okay, here's the translation:
"Just so you know, I'm planning to modify my fuel injection pump to use 11mm pistons."
I still have a pump from the SDI AEY.
Is it reasonable to rebuild the SDI pump and then install it?
Or, to put it another way, does it even work?
What are the differences between the pumps?
Best regards.
Sven.
96´Passat 35i TDI AFN Syncro
Umbau auf 4-Motion
04´Passat 3BG V6 TDI 4-Motion
Translated on 27-09-2026, 19:02.
Post26-03-2009, 13:22    Subject: SDI vs. TDI Fuel Injector Pump: Differences Quote
Is this probably about your AFN?
I would not use the SDI pump.
It will probably work out somehow, but the pumps are only slightly different.
To my knowledge, even the 90 HP and 110 HP pumps are different, for example, in the shape of the plunger and, consequently, the injection process.
Translated on 27-09-2026, 19:03.
No new posts P261A, P261B - Pump for coolant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts Golf 1J Headlight Washer Pump Leak - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts differences in the 1Z Diesel Engine Technology
No new posts Cable differences Transmission, Chassis, Body & Interior
No new posts AFN Cylinder Head Differences Diesel Engine Technology
No new posts ECU Names: Differences and Explanations On-Board Diagnostics (OBD)
