Audi A3 8L: Rusted Door Replacement
Gremlin
Avatar-Gremlin
Karma: +91 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post03-03-2009, 14:40    Subject: Audi A3 8L: Rusted Door Replacement Quote
Hey guys,
The following problem:
- The lower trim pieces on my Audi A3, manufactured in 09/99, were removed at the authorized service center, and it was discovered that both doors are partially rusted underneath.
Key point: Two years ago (while still within the warranty period), they were already repaired free of charge (by the authorized workshop mentioned above), and the last maintenance services were performed by an independent garage, but regularly.
What about the 10-year anti-corrosion warranty? My understanding is that it becomes void if any work has been done on it, especially if it involves the zinc coating.
Please provide the German text you would like me to translate into English. I will then give you only the translation, without any explanations.
Update:
On March 31st, someone from the Audi factory will come and inspect the vehicle. Presumably (although I wasn't explicitly told this), they will be checking whether the last goodwill repair was carried out correctly.
and
After a Google search, I investigated the vehicle further.
Rust is also forming under the paint on the left side of the roof ridge.
Translated on 21-08-2026, 17:57.
Gremlin
Avatar-Gremlin
Post31-03-2009, 17:30    Subject: Audi A3 8L: Rusted Door Replacement Quote
Hello everyone icon_razz.gif;
Good news (for me): The doors will be replaced, and the edge of the roof will also be repaired.
Unfortunately, the repair to the door was incorrectly done by the workshop back then (or so I understood). They used the wrong type of rust primer (red), which supposedly hasn't been allowed to be used since 2005.
Translated on 21-08-2026, 17:59.
Post31-03-2009, 23:54    Subject: Audi A3 8L: Rusted Door Replacement Quote
You've been lucky again. But that rust issue on the roof is a real problem with the A3. I've seen some really bad cases, especially with those very early models from '96.
Translated on 21-08-2026, 18:00.
No new posts A3 Door Noises: Documentary & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3: Rear Door Corrosion - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf IV / Octavia 1 Water ingress at the doors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8V - Automatische Absperren der Türen beim Losfa... On-Board Diagnostics (OBD)
No new posts Golf 2 Holm durchgerostet :( Transmission, Chassis, Body & Interior
No new posts Rust Repair: Lupo Tailgate Rust & Quick Fixes Transmission, Chassis, Body & Interior
No new posts Door Knocks: Secrets & Hidden Meanings Transmission, Chassis, Body & Interior
