| đ â đ¨ |
| Throttle Body Initial Setup with VCDS (Gasoline Engine) | |
| dieselschrauber |
The following steps describe the throttle body basic adjustment with VCDS for most Audi, Seat, Skoda and Volkswagen with gasoline engines.
The throttle position sensor (TPS) baseline setting informs the engine control unit (ECU) about the throttle position at specific positions/load conditions. The TPS baseline setting is generally only useful in engines where the throttle is moved by a stepper motor controlled by the ECU.D.h. normally, there is also no blanking-stabilizing valve installed. Reasons to perform a throttle body adjustment:
Ignition ON, but engine not starting. [Choose] [01 - Engine] [Measurement Blocks - 08] Set value block 098. (Warning: Some SIMOS or Marelli control units use measurement block 001, e.g.ADY & AEE Engines. [Okay!] [Default Mode] After that, the VCDS display shows 'ADP RUN'.After the setting is complete, wait for approximately 30 seconds and then switch back to the data blocks and terminate the connection to the control unit. During the procedure, remove your feet from the accelerator and turn off the engine! Vehicles with electronic throttles that use KWP1281 for diagnostics Ignition ON, but engine not starting. [Choose] [01 - Engine] [Measurement Blocks - 08] Set value block 060. [Okay!] [Default Mode] After that, the VCDS display shows 'ADP RUN'.After the setting is complete, wait for approximately 30 seconds and then switch back to the data blocks and terminate the connection to the control unit. During the procedure, remove your feet from the accelerator and turn off the engine! Vehicles with electronic throttles that use KWP2000 or CAN for diagnostics Ignition ON, but engine not starting. [Choose] [01 - Engine] [Default Settings - 04] Set value block 060. [Okay!] VCDS should display 'Default setting: OFF'. Select [ON/OFF/Continue] to enable the default settings. VCDS should now display 'Default Setting: ON'. After the setting is complete, wait for approximately 30 seconds and then use [ON/OFF/Continue] to complete the basic setting (VCDS: 'Basic setting: OFF'). During the procedure, remove your feet from the accelerator and turn off the engine! Dipl.-Ing. (FH) Rainer Kaufmann - Original VCDS mit KPower, KDataScope und Dieselschrauber Support Translated on 03-07-2026, 15:19. |
| Ratings - Throttle Body Initial Setup with VCDS (Gasoline Engine) | |
Average rating: 4.50 - worst rating: 4 - best rating: 5 - number of ratings: 2 - View ratings |
| đ â đ¨ |
Foren- und Portal-Software: V7.9 © 2003 - 2026 Kaufmann Automotive GmbH & Shop fĂźr Kfz-Diagnosegeräte. Parse time: 0.081s
