Which A5 has double-link exhaust pipes?
Post10-05-2009, 20:13    Subject: Which A5 has double-link exhaust pipes? Quote
HI
I thought the A5 models always had duplex end tubes.
Yesterday, I saw a car in front of me that had double left turn signals.
What engines are available for it?
(The 2005 A6 even has a showy dual exhaust system with its 140 hp TDI engine and front-wheel drive.)
Translated on 05-07-2026, 1:29.
Post10-05-2009, 22:09    Subject: Which A5 has double-link exhaust pipes? Quote
Definitely the 1.8 TFSI with 170 horsepower. I don't know about the others.
Post10-05-2009, 22:29    Subject: Which A5 has double-link exhaust pipes? Quote
I just took another look at Autoscout, and I found the following models that don't have dual exhaust pipes:
-1.8 TFSI with 170 horsepower.
- 2.0 TFSI engine with 180 horsepower.
- 2.0 TFSI engine with 211 horsepower.
- 2.0 TDI engine with 170 horsepower.
However, those were all the models, and none of them were Quattro versions!
Translated on 05-07-2026, 1:30.
Octavia_4x4
Post11-05-2009, 5:26    Subject: Which A5 has double-link exhaust pipes? Quote
As far as I know, only the Quattros have the dual exhaust system, probably because there isn't enough space for a regular exhaust system in the rear due to the design. For example, this was also done with the Passat 3BG, which had split rear silencers even in the V6 4motion models.
Translated on 05-07-2026, 1:31.
Post11-05-2009, 7:49    Subject: Which A5 has double-link exhaust pipes? Quote
As I said, I also _thought_ that (regarding the Quattro topic).
But an A6 front lip spoiler has taught me otherwise.
On the other hand, the 3C TDI 4Motion does NOT have a duplex system.
It seems to be more of an optical issue.
Post11-05-2009, 8:06    Subject: Which A5 has double-link exhaust pipes? Quote
Martin, what ever changing interests you have! icon_smile.gif From the underpowered bus to the left-hand lane highway drift... icon_smile.gif. Are all the Dublex 3c models gasoline-powered with 4Motion?
Perhaps it also has something to do with the model year and the current trend towards minimalism.
Translated on 05-07-2026, 1:32.
Post11-05-2009, 8:17    Subject: Which A5 has double-link exhaust pipes? Quote
Martin is certainly NOT changing his interests.
"That left-hand turn wasn't properly cleared on the weekend."
It was going around 210 km/h in front of me, but it seemed like it was accelerating a lot.
He fared a little better than I did.
I think he was also a bit surprised that the "Pampersbomber" was even invited.
I always thought the A5 range started around 350 horsepower icon_smile.gif.
I also always thought that all-wheel drive and duplex were related.
To be honest, I've never actually seen a 3C diesel engine with a Duplex system. The Duplex models at 3C that I've seen have always been gasoline-powered.
Translated on 05-07-2026, 1:33.
Post11-05-2009, 9:06    Subject: Which A5 has double-link exhaust pipes? Quote
Translated on 05-07-2026, 1:34.
Post11-05-2009, 9:16    Subject: Which A5 has double-link exhaust pipes? Quote
I just found a 2.0 TFSI Quattro with 211 horsepower. It also didn't have the Duplex system. So, it has nothing to do with Quattro or front-wheel drive either.
Translated on 05-07-2026, 1:35.
Post11-05-2009, 9:29    Subject: Which A5 has double-link exhaust pipes? Quote
Sure, here's the translation:
"Thank you, TDI-GTI-4-Motion."
The comment made me realize that the BMW 5-series used to differentiate exhaust pipes based on the number of cylinders: a single exhaust pipe for 4-cylinder engines, and dual exhausts for engines with 6 cylinders or more.
Audi does this too, at least according to the price list, in a place where I wouldn't have expected it.
Exhaust tailpipes, visible, dual exhaust, with one tailpipe on the left and one on the right; for A5 Coupe 1.8 TFSI, 2.0 TFSI and
2.0 TDI, single-sided, two tailpipes on the left; for A5 Cabriolet 2.0 TDI, single-sided, two tailpipes on the left
However, this contradicts the configurator, which changes the images depending on the engine selection.
Translated on 05-07-2026, 1:36.
No new posts Golf3 pulls to the left (SOLVED) General Tips
No new posts LLK for G3 AFN: Find the Right Fit Diesel Engine Technology
No new posts Turbocharger: Which One Is Best? Diesel Engine Technology
No new posts Diesel Filter: Which one is right? Diesel Engine Technology
No new posts Which car radio adapter? Diesel Engine Technology
