Turbocharger: Limiting Boost with Pressure, Not Mass Airflow
Klausel
Post06-05-2009, 19:03    Subject: Turbocharger: Limiting Boost with Pressure, Not Mass Airflow Quote
In the article about LLMs, it states:
In some TDIs, the soot limit is not calculated based on the mass airflow sensor (MAF) value, but rather based on the boost pressure.
So far, my search has only revealed these two manufacturers of 3-cylinder engines: AMF and BAY.
Which other ICD codes are relevant?
Thank you for the responses.
Best regards, Klaus.
Translated on 24-09-2026, 19:29.
Wiesel
Post06-05-2009, 19:28    Subject: Turbocharger: Limiting Boost with Pressure, Not Mass Airflow Quote
Hello Klaus,
You can't necessarily attribute that to the MKB. For example, there are also ASZ or AXR that do that.
have. For example, you can find them with all the numbers "038 908 019 N?". "Luck" is definitely involved (there are many of them).
Specifically, I haven't checked that.
Best regards, Micha.
Translated on 24-09-2026, 19:30.
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post08-05-2009, 11:47    Subject: Boost Limit Calculation: Russ vs. LM Quote
Definitely 1T!
The engine didn't have a mass airflow sensor at all icon_razz.gif.
However, the underlying program files are likely to have disappeared into the mists of history icon_rolleyes.gif.
Marcus "Ar Gwenn": Für uns sind Leute arm, weil sie mit einem Eselskarren unterwegs sind, für sie sind wir arm, weil wir ein Leben lang dafür arbeiten und Geld verdienen müssen, um uns im Alter von wildfremden Leuten pflegen zu lassen.
Translated on 24-09-2026, 19:31.
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Systematic approach for identifying defects. WaPu 1.9 TDI... Diesel Engine Technology
No new posts Tire Size: 195/60 vs. 195/65 Transmission, Chassis, Body & Interior
No new posts TDI Engine Swap: Replacing 1.8 ADZ Engine Diesel Engine Technology
No new posts Sport Air Filters vs. Turbo: Which is Best? Diesel Engine Technology
