3C: Chiller return line rattles
Post02-03-2009, 9:15    Subject: 3C: Chiller return line rattles Quote
Hi.
Between the suction nozzle and the LuFiKa, the thin "coolant return" hose runs. It has an extra thickening to prevent it from chafing. Because one end is connected to the motor and vibrates with it, while the other end is fixed to the radiator.
Unfortunately, the hose was lying around very loosely.
Does anyone have any ideas on how to calm him down?
Interestingly, it seems to be quieter when the engine cover is on, because then it presses his "engine end" slightly downwards, which keeps him firmly pressed against the intake manifold.
 File size:  102.13 KB
 Viewed:  2866 times
Post06-03-2009, 20:44    Subject: 3C: Chiller return line rattles Quote
I don't see a problem there, or are you hearing that clattering sound? Is there a way to attach it securely nearby, perhaps using a cable tie?
Post06-03-2009, 20:56    Subject: 3C: Chiller return line rattles Quote
I'm not sure.
However, after the last service, I've noticed a slightly different running noise, particularly around 1300 rpm. Since a sensor was replaced, I initially thought it might be due to a cable touching something. However, the replacement unit has a fixed cable routing on the valve cover.
Since the mechanics at the workshop didn't properly attach the engine cover, I'm currently driving without it, and I've discovered that the "Böppel" (presumably a specific part) is now very loose.
It's a shame so much has changed.
- New woofer (the actual reason).
- alternative engine software.
- without engine cover
Ah icon_wink.gif maybe the horn is poorly wired and resonates at 1300....
Post06-03-2009, 21:00    Subject: 3C: Chiller return line rattles Quote
Okay, put the engine cover back on because you mentioned that it reduces vibrations! Was the horn working? I can even hear it, even though I don't hear very well, I am deaf! icon_cool.gif Of course, only when I am near the horn. icon_wink.gif
Post06-03-2009, 21:06    Subject: 3C: Chiller return line rattles Quote
Yes, that's the second low-frequency horn my Passat has eaten.
Two failures in two years - luckily, both were covered by warranty.
Post07-03-2009, 1:03    Subject: 3C: Chiller return line rattles Quote
I just went for another ride (it's nice and quiet at night).
Something is squeaking in the engine compartment. It could also be caused by changes to the injection parameters introduced by the software update.
It sounds more like a knocking or fluttering – perhaps it's just one of those aluminum fabric covers above the DPF.
I hate this kind of thing...
Post07-03-2009, 9:37    Subject: 3C: Chiller return line rattles Quote
Hi Martin,
Just cut out a thick foam ring and glue it on. For years, there has been a Glitzi sponge under the air filter box of my A3, with the rough side facing the air intake.
Don't worry about the rust on the car; it's just somewhere else.
Post11-03-2009, 9:19    Subject: 3C: Chiller return line rattles Quote
I'll do something like that.
Or, you can cable-tie the part to the opening in the air duct.
Post20-05-2009, 7:09    Subject: 3C: Chiller return line rattles Quote
Okay.
That stupid hose never stays where I push it.
Therefore, I secured him (and also the ATM throttle next to the mass airflow sensor):
 File size:  36.96 KB
 Viewed:  2099 times
 File size:  49.69 KB
 Viewed:  31971 times
Post20-05-2009, 8:15    Subject: 3C: Chiller return line rattles Quote
Cool idea with the heating pipe insulation icon_smile.gif.
Post20-05-2009, 8:20    Subject: 3C: Chiller return line rattles Quote
Rainer K. wrote:
Thank you icon_smile.gif.
- cheap
- works.
- If it's too tight, the insulation will be the first thing to rub away - so it won't damage any original parts.
The clip connection "thick U-shaped pipe to LuFiKa inlet" already showed clear signs of wear, so I reinforced it with original VW fabric tape. (Unfortunately, no photos were taken).
Post20-05-2009, 9:30    Subject: 3C: Chiller return line rattles Quote
dieselmartin wrote:
I then reinforced it with original VW fabric tape
What kind of tape are you talking about? Could it be the kind I've been looking for forever? This felt material is used to wrap the cable harnesses.
Post20-05-2009, 10:18    Subject: 3C: Chiller return line rattles Quote
Sure.
Exactly that. I searched for a long time too.
000 979 950 Textile adhesive tape, black, approx. 5.00€ per piece.
Original VW and, surprisingly, even affordable icon_smile.gif.
With Alex, you can see how it is.
http://www.passat3c.info/cms_neu/index.php?page=152
I wrapped a layer of it around the U-shaped tube and then clipped it back into the air filter housing. It's now firmly attached and without any rattling.
Post20-05-2009, 13:14    Subject: 3C: Chiller return line rattles Quote
Thank you very much, Martin. You wouldn't believe how long I've been looking for it. I would never have thought to ask Volkswagen about that.
wolfi_b
Post25-05-2009, 8:08    Subject: 3C: Chiller return line rattles Quote
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T6 Seatbelt Rattle: Fix It Now! Transmission, Chassis, Body & Interior
No new posts Hydraulic lifters ticking VW Passat 3BG AVF Diesel Engine Technology
No new posts TDI Ibiza: BPX Knocking Noise - Causes & Fixes Diesel Engine Technology
No new posts Golf 3 Diesel 1Y: Why is it rattling? Diesel Engine Technology
