AEL TDI: Single or Twin Mass Flywheel?
roorback
Karma: +1 / -2   Thank you, like it!
Post19-05-2009, 11:29    Subject: AEL TDI: Single or Twin Mass Flywheel? Quote
hello
A well-known person mentioned that you can identify whether a car has an EMS (Electronic Manual System) or a ZMS (Zero-Point Manual System) by looking at the gearbox. If it has an EMS, the sensor is mounted on the gearbox and there's a fork that goes into the gearbox. If it has a ZMS, the sensor is directly inside the gearbox.
Okay, here's the translation:
"Now, there's a real difference. On the February 1997 TDI model, I have the sensor on the transmission and a lever. On the later model (late 1997), I only have a hose going into the transmission, and definitely a dual-mass flywheel."
After I planned to use the parts from the "Schlachter" (a source for used parts) for the upcoming clutch replacement, I need to know if it's actually possible that my TDI has an EMS (Engine Management System).
"Thank you."
best regards, uwe
Translated on 04-09-2026, 9:18.
christians
Post20-05-2009, 20:49    Subject: AEL TDI: Single or Twin Mass Flywheel? Quote
To the best of my knowledge, all 5-cylinder TDI engines, starting from 1994 or with the renaming of the Audi 100 to the A6, have a dual-mass flywheel.
Gruß Christian
Translated on 04-09-2026, 9:19.
roorback
Post21-05-2009, 11:23    Subject: AEL TDI: Single or Twin Mass Flywheel? Quote
"Thank you!"
I heard from "the rolling community" that the Volvo only used the ZMS (dual-mass flywheel).
"However, since there are more people working on gasoline engines there, and with gasoline engines, the change from an EMS (Electronic Motor System) to a ZMS (Mechanical System) is related to the sensor cylinder on the transmission, or then with a ZMS central release mechanism, I was a bit confused."
In the TDI engine, the older fork and central release bearing configuration should have a dual-mass flywheel (DMF).
"Hello"
Translated on 04-09-2026, 9:20.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts Clutch Slipping: Effects on Engine Power and Performance Diesel Engine Technology
No new posts S3 or S4 seats in an Audi 80 or other sports seats? Transmission, Chassis, Body & Interior
No new posts Immobilizer system, version 2 or 3 / with or without CAN ... On-Board Diagnostics (OBD)
No new posts TDI 110/115 PS: Specs & Performance Diesel Engine Technology
