Injector Replacement at AEL
selbstschrauber
Post29-05-2009, 12:42    Subject: Injector Replacement at AEL Quote
Hello everyone!
I plan to replace the injectors on my C4, manufactured in 1995, with 140 horsepower, and with 200,000 km on the odometer.
However, about half a year ago, I replaced the nozzle with the needle-actuator alone, because it was unfortunately defective and kept jamming! I can no longer afford the others icon_sad.gif
Now I'm faced with the dilemma of choosing!! Is it more sensible to incorporate larger ones, or should I stick with the new one with the needle guide and just replace the remaining 4?
Best regards, Hannes
Post29-05-2009, 13:01    Subject: Re: Injector Replacement on AEL Quote
selbstschrauber wrote:
Is it sensible to incorporate larger ones
If you might want to upgrade to more performance later on, yes. If you want to leave it as is, then it's pointless.
selbstschrauber
Post29-05-2009, 20:28    Subject: Injector Replacement at AEL Quote
Does 'more performance' refer to software tuning or upgrading to a larger turbo...?
Post29-05-2009, 22:50    Subject: Injector Replacement at AEL Quote
Upon conversion to a large turbo. So, for 30 more horsepower, you don't need any other nozzles yet.
selbstschrauber
Post30-05-2009, 13:24    Subject: Injector Replacement at AEL Quote
So, ich kann den mit dem Needle-driver einfach so lassen, wie er ist, und die anderen 4 mit diesen Düsen:
http://shop.dieselschrauber.de/product_info.php/cPath/36/products_id/77
repair??? Or is it not safe to know which size the original has in relation to the needle?
Post30-05-2009, 13:35    Subject: Injector Replacement at AEL Quote
I don't know what size AEL originally used. But I don't think they were 216s. Just use the search function. You'll figure out what's installed.
No new posts Fuel injector replacement: Tuning without electronic modi... Technical Articles
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Fuel Injector Problems: Leak After Replacement Diesel Engine Technology
No new posts Injector Replacement: Strange Clicking Noise? Diesel Engine Technology
This topic is locked, you cannot edit or reply. Fuel Injector Replacement: Stuttering, Power Loss, Misfire Diesel Engine Technology
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
