Timing Belt Replacement BLS Engine - Seat Leon
audiavus
1992 Audi 100
Registered VCDS User
Post20-09-2011, 19:17    Subject: Timing Belt Replacement BLS Engine - Seat Leon Quote
hi
Is there anything special to consider when replacing the timing belt on a 2005 Leon with a BLS engine? Or is it as straightforward as described in this guide?
Okay, I'm ready. Please provide the German text you want me to translate into English. Just paste it here, and I will give you the translation.
Sommer: 1992er Audi 100 typ C4 mit 2,5L 7A Motor - Der Einzigartige
Winter: 1991er Audi 100 typ C4 mit AAR Motor
Schönwetter: 1990er Audi Coupe Quattro Perlmuttweiß mit 7A Motor
Translated on 20-08-2026, 5:04.
BM
Avatar-BM
Post20-09-2011, 20:12    Subject: Timing Belt Replacement BLS Engine - Seat Leon Quote
Yes, carefulness. I have personally never removed a bumper like that before.
And do yourself a favor by briefly marking the position of the ZR wheels with a marker before disassembling them.
With that, you and we can avoid things like this: https://community.dieselschrauber.org/en/viewtopic.php?t=25731
I would replace the tensioner pulley's pivot bolt as well.
If the tensioner is accidentally tightened too much during adjustment, you must first completely release the tension and then re-tension it again in the direction of the arrow.
3B5 AJM
Translated on 20-08-2026, 5:05.
audiavus
1992 Audi 100
Post21-09-2011, 6:03    Subject: Timing Belt Replacement BLS Engine - Seat Leon Translating...
[Translating...]
Post21-09-2011, 8:17    Subject: Timing Belt Replacement BLS Engine - Seat Leon Quote
Hi.
Please take lots of pictures.
My car's inspection is due in 15,000 km (approximately 9,320 miles).
Thank you.
Translated on 20-08-2026, 5:06.
audiavus
1992 Audi 100
Post16-10-2011, 12:39    Subject: Timing Belt Replacement BLS Engine - Seat Leon Quote
Unfortunately, the photos didn't work out; we got a bit stressed because some parts were delivered incorrectly icon_confused.gif.
Finding the timing mark was a bit strange because, oddly enough, none of the rotor tips aligned with the "Z" marking. I also couldn't fit the camshaft locking pin (which was the original special tool). So, it ended up being a process of trial and error, but thankfully, it worked out in the end...
Translated on 20-08-2026, 5:07.
No new posts Seat Leon, 2012 model, LED brake light flickering Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement for transversely mounted PD engine Troubleshooting & Guides
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Coolant fan for Seat Leon 1M (ARL engine) with air condit... Transmission, Chassis, Body & Interior
No new posts Vag-Com Codes für Seat Leon Diesel Engine Technology
No new posts Seat Leon 1P: Ansteuerzeit Scheinwerferreinigung On-Board Diagnostics (OBD)
No new posts Seat Leon: Disable Seatbelt Warning Light On-Board Diagnostics (OBD)
