Does the engine control unit 028 906 021 AF have a WFS (Waste Heat System), or are there versions without it?
t4tom
Avatar-t4tom
Post21-06-2009, 15:51    Subject: Does the engine control unit 028 906 021 AF have a WFS (Waste Heat System), or are there versions without it? Quote
A question: I want to install a 1Z engine with a 028 906 021 AF engine control unit (ECU) into a T4. My questions:
Was there a version of this control unit without the WFS?
What are some possible signs that a suspected WFS (Wind Shear) might be present? I only have the motor with the wiring harness.
"Could this control unit possibly be adapted to fit my T4 WFS (which is a Multivan from 1995)?"
Probably a first-generation WFS (Wireless File System).
Thank you in advance.
Best, Tom.
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Bremsflüssigkeits-MIL ohne Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 8P1 AC Not Working: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts It also works without a fuel injector Diesel Engine Technology
No new posts Brake Cleaner: Bosch vs. Pierburg - Which is Best? Diesel Engine Technology
No new posts Golf VI: CAYC Engine Coding (or Not) On-Board Diagnostics (OBD)
No new posts Lowering a Golf IV T...just springs or also dampers (35mm)? Transmission, Chassis, Body & Interior
