Thicker Stabilizer Bar for Reduced Sway
brezelmann01
Post23-05-2009, 12:43    Subject: Thicker Stabilizer Bar for Reduced Sway Quote
Hello!
"My Polo has been feeling a bit too unstable in corners from the beginning. It has the standard suspension, which has already been replaced (the shock absorbers). Now I've noticed that there are actually 3 different stabilizer bars for the front axle: 18mm (which is currently installed), 20mm, and 22mm. Would switching to the 22mm stabilizer bar (along with the necessary other parts) significantly reduce the body roll? Or would that not make sense? Otherwise, I don't want to sacrifice the comfort of the standard suspension."
Dirk.
Translated on 17-10-2026, 10:34.
Post23-05-2009, 13:21    Subject: Stabilizer for Reduced Sway: Which is Best? Quote
brezelmann01 wrote:
Would switching to a 22mm stabilizer significantly reduce the wobble?
Clearly, no. A little bit, yes.
Translated on 17-10-2026, 10:35.
EMSimASZ
Post23-05-2009, 14:10    Subject: Thicker Stabilizer Bar for Reduced Sway Quote
I replaced all the rubber bushings in the suspension of my car (front and rear) with BONRATH bushings. I also got two aluminum tie rods from a friend. These tie rods don't have rubber bushings, but instead have sealed swivel joints. So, everything is upgraded. Since then, the car feels very stiff. However, I also have an H&R coilover suspension. Combined with the stiff bushings and the tie rods, it's a dream to drive.
Translated on 17-10-2026, 10:36.
Karma: +1102 / -0   Thank you, like it!
Post23-05-2009, 15:08    Subject: Thicker Stabilizer Bar for Reduced Sway Quote
I believe it's beneficial to replace the stabilizer bars with stiffer ones, perhaps made of plastic. This would enhance the response of the stiffer stabilizer bars. In the uncompressed state, the impact on ride comfort should be minimal. However, when the body rolls during cornering, the progressive characteristic of the stabilizer bars (torsion element) eventually comes into play.
If it's worth the effort to you, then go ahead and try it, and use stronger stabilizers right away!
Translated on 17-10-2026, 10:37.
Post23-05-2009, 16:22    Subject: Thicker Stabilizer Bar for Reduced Sway Quote
However, you should all keep in mind: If the dampers are too soft, even the toughest Sabi won't work miracles icon_exclaim.gif.
Translated on 17-10-2026, 10:38.
Post23-05-2009, 16:50    Subject: Thicker Stabilizer Bar for Reduced Sway Quote
Despite its progressive effect, you should still notice a difference. As brezelmann01 mentioned earlier, he finds the soft suspension of the standard chassis quite pleasant, and the only thing that bothers him is the tendency to lean in corners. In my opinion, there's not much more that can be done if the comfortable suspension setup is to be maintained. Those who regularly drive on cobblestone roads, forest paths, or field tracks, or, for example, on the crater-filled roads of the capital city, might not want a very stiff suspension. I can at least understand that.
Translated on 17-10-2026, 10:39.
Post23-05-2009, 18:32    Subject: Thicker Stabilizer Bar for Reduced Sway Quote
You can definitely tell that something is wrong, that's clear. But, as you mentioned earlier, is the effort worth it for him?
brezelmann01
Post23-05-2009, 19:08    Subject: Thicker Stabilizer Bar for Reduced Sway Quote
Okay, those are some interesting points to consider! Where can you tell which parts are "harder" and which aren't? I'm not really familiar with suspension topics. Is this kind of thing only available in the aftermarket?
Translated on 17-10-2026, 10:40.
Post23-05-2009, 21:18    Subject: Thicker Stabilizer Bar for Reduced Sway Quote
brezelmann01 wrote:
Is this only available in accessory stores?!
Yes, for example, Powerflex makes them, and they are blue. There are probably other manufacturers as well, but not VW.
cetano
Avatar-cetano
Post19-06-2009, 22:59    Subject: Thicker Stabilizer Bar for Reduced Sway Quote
A comfortable and cozy suspension setup... sounds good.
In addition to their influence on handling characteristics, stabilizers and their combinations on the front and rear axles also serve another important purpose in suspension tuning.
You might want to research the influence that stabilizers and their coordinated combination of front and rear axles have on the oversteer/understeer behavior of vehicles in critical situations.
A "thicker stabilizer bar" at the rear, for example, means that the tendency for oversteer increases. If the rear axle isn't adjusted accordingly, it can have negative consequences.
Fortunately, there are systems like ESP (Electronic Stability Program) that can compensate for these errors to a certain extent. It all comes down to physics and logical thinking.
The company's engineers worked tirelessly for years on that.
Sorry, I just had to get that off my chest.
Kfz-Prüfstelle des TÜV Rheinland/FSP Saalfelder Höhe in Thüringen im grünen Herzen Deutschlands.
Wir lieben Diesel, vor allem alte..
Sommer: Oldtimer W124 2,5 Saugdiesl 90 PS Bj 87, Winter: Golf4 4Motion TDI AGR
Translated on 17-10-2026, 10:41.
Back to top Profile PM Email
No new posts Golf 3 TDI 90 hp, brakes? Stabi? Transmission, Chassis, Body & Interior
No new posts Golf 4 4Motion Stabilizer Bar Transmission, Chassis, Body & Interior
No new posts H&R Anti-Roll Bar for VW Golf 4 4Motion: Does it work? Transmission, Chassis, Body & Interior
