Polo 9N3: Only 1 AXR Radiator Fan?
Klausel
Post06-05-2010, 18:33    Subject: Polo 9N3: Only 1 AXR Radiator Fan? Quote
The above-mentioned car, model year 2006 (recently purchased), only has...
a single fan on the water cooling system.
Does it operate in multiple stages, especially when the climate control is turned on?
Or are we actually missing the second one?
Best regards, Klaus.
Translated on 24-10-2026, 10:30.
Post07-05-2010, 5:23    Subject: AXR Polo 9N3: Only One Cooling Fan? Quote
Klausel wrote:
The above-mentioned car, model year 2006 (recently purchased), has only...
According to Etzold, there should be 2 (including the climate section) ... icon_eek.gif
Well, repair manuals can already be outdated in detail before the first copy is available for sale.
But even our non-climate-controlled ASZ-9N model from 2004 came with two radiator fans from the factory.
Translated on 24-10-2026, 10:32.
Post07-05-2010, 8:55    Subject: AXR Polo 9N3: Only One Cooling Fan? Quote
Klausel wrote:
... only has a single fan on the water cooler. (...) Or are we actually missing the second one?
According to my information, for the 2006 Polo, there should only be one version available.
But as an AXR driver with climate control, you at least got the biggest one: 390mm, 260/90 watts.
What makes me pause, however, is Ulf's statement, because even for the years 2003/4, I can only find one fan.
Only in the wiring diagrams for the years 2001-2003 is a second radiator fan shown, with the note: "Not for vehicles with air conditioning."
Ulf probably has two smaller fans, while you have one larger and overall more powerful fan.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 24-10-2026, 10:34.
Klausel
Post07-05-2010, 9:20    Subject: AXR Polo 9N3: Only One Cooling Fan? Quote
I had already suspected that the front of the car had been rebuilt at some point.
Yes, that thing is massive; it certainly generates a lot of thrust. icon_wink.gif
Translated on 24-10-2026, 10:36.
Post07-05-2010, 9:42    Subject: AXR Polo 9N3: Only One Cooling Fan? Quote
guste100 wrote:
Ulf probably has two small fans, while you have one larger and overall more powerful fan inside.
No, there was also one large and one small fan inside.
I, of course, amputated the little one (for weight reasons). icon_twisted.gif
Translated on 24-10-2026, 10:37.
Klausel
Post07-05-2010, 10:59    Subject: AXR Polo 9N3: Only One Cooling Fan? Quote
ulf wrote:
There was also one large one and one small one.
"Just like in my 1997 AFN. The small one starts running immediately when the AC is turned on."
Therefore, I always thought that it was mainly used to cool down the surrounding area.
It's circulating with a coolant that is compressed and therefore heated.
Wenn das stimmt: wie ist dann im AXR Polo diese KĂźhlung ersetzt? Is there any?
Is this part similar to a fuel cooler?
Translated on 24-10-2026, 10:38.
DieselBär30x
Avatar-DieselBär30x
Post07-05-2010, 11:21    Subject: Polo 9N3: Only 1 AXR Radiator Fan? Quote
Hello everyone!
Clause, don't you have a (large) Visco fan and a small electric fan inside the AFN unit?
...in my A4, manufactured in 1998, it's configured this way, with a Climatronic system and a factory-installed tow hitch, which results in increased cooling.
Best regards from Munich!
Translated on 24-10-2026, 10:40.
Post07-05-2010, 11:39    Subject: Polo 9N3: Only 1 AXR Radiator Fan? Quote
DieselBär30x wrote:
Clause, don't you have a (large) Visco fan and a small electric fan inside the AFN?
Visco fans, which are directly driven by the engine, are only found in engines mounted longitudinally: This includes older Passats and Audis, as well as V6 and V8 engines.
A viscous fan would be too complex for a transverse engine. Therefore, the Polos definitely only have electric fans. It's possible there's still an older configuration: an electric fan and a second fan blade driven by a V-belt connected to the first electric fan. However, I doubt that's still the case today.
@Ulf:
Since you removed the second fan: Do you have it somewhere within easy reach? Then you could post the part number, and we could see why it's installed there, even though you can't see it.
Greetings.
Translated on 24-10-2026, 10:42.
DieselBär30x
Avatar-DieselBär30x
Post07-05-2010, 12:42    Subject: Polo 9N3: Only 1 AXR Radiator Fan? Quote
Yes... Those who can read the title of the topic often have a clear advantage icon_wink.gif.
Okay, then I'll just be quiet about this *g*.
Translated on 24-10-2026, 10:43.
Klausel
Post07-05-2010, 13:14    Subject: Polo 9N3: Only 1 AXR Radiator Fan? Quote
DieselBär30x wrote:
Whoever can read the title of the topic,
Yes, the (red-labeled) AFN has received an increase in green AXR shares...
Likewise.
Translated on 24-10-2026, 10:44.
Post07-05-2010, 13:36    Subject: Polo 9N3: Only 1 AXR Radiator Fan? Quote
guste100 wrote:
@Ulf:
Since you removed the second fan: Do you have it somewhere easily accessible? Then you could post the part number, and we could see why it's there, even though I can't see it.
1J0 121 206 D
Fan diameter = 29 cm, mounted on the passenger side.
Translated on 24-10-2026, 10:45.
Post07-05-2010, 15:28    Subject: Polo 9N3: Only 1 AXR Radiator Fan? Quote
I'm completely confused. What's the Polo, and what's the Polo Classic? The latter was produced from 2004 to 2009, while the other was produced from the 1970s to the present day.
Ulf's part number belongs to the Polo CLASSIC (and is only the three-arm bracket for the fan icon_wink.gif). It doesn't specify exactly when or how many fans are installed. There is definitely a large fan and a small fan that can be mounted at the same time. (Unlike the Polo Non-Classic).
There are two different versions of the smaller fan (single-stage / two-stage).
Translated on 24-10-2026, 10:46.
Post07-05-2010, 16:14    Subject: Polo 9N3: Only 1 AXR Radiator Fan? Quote
guste100 wrote:
Ulf's part number belongs to the Polo CLASSIC (and is only the three-arm fan holder icon_wink.gif).
That was the only number I found initially.
Just now, I discovered a small identification plate on the metal housing, located in the narrow gap between the bracket and the propeller cap: the part number is 6Q0 959 455 L.
The fan is 2-speed (3-pole).
Translated on 24-10-2026, 10:48.
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Vibration Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N 1.4 TDI - Radiator Fan Diesel Engine Technology
No new posts Radiator Fan Runs at Level 2 - Normal? Diesel Engine Technology
No new posts Polo 6R On-Board Diagnostics (OBD)
No new posts VW Polo TDI: Specs, Features, & More Diesel Engine Technology
