PIN Layout Comparison: 1Z Engine Control Units
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post27-07-2009, 15:47    Subject: PIN Layout Comparison: 1Z Engine Control Units Quote
Is there a publicly available PIN assignment for engine control units (ECUs) anywhere?
1Z, manufactured in 1996, MSA16.
against
1Z, manufactured in 1993, MSA8 from an Audi 80, with a VP37 and a potentiometer-based quantity control.
I would like to know what changes need to be made to the engine wiring harness when switching from version 1 to version 2.
I already know that the pump connector is different.
Thank you and best regards.
Jens.
Translated on 19-10-2026, 5:51.
Post27-07-2009, 16:41    Subject: PIN Layout Comparison: 1Z Engine Control Units Quote
If I remember correctly, this doesn't work because of a different type of sensor used at the fuel injection pump (a potentiometer instead of an inductive sensor).
Translated on 19-10-2026, 5:52.
Jens 16syncro
Post28-07-2009, 5:48    Subject: PIN Layout Comparison: 1Z Engine Control Units Quote
Hi Rainer,
I didn't intend to mix MSG and ESP; rather, I would combine an older ESP with a compatible older MSG, using the potentiometer.
Unfortunately, there are still a few cables running between the ESP and MSG modules, and I'm very curious to know where the differences lie in the wiring harnesses.
"The pump connector is already different, as there are various types."
The LMM (mass airflow sensor) is likely not compatible, although I'm not sure whether the older Audi 1Z model still uses a hot-wire LMM or the more modern hot-film version.
Jens.
Translated on 19-10-2026, 5:53.
wolfi_b
Post28-07-2009, 9:51    Subject: PIN Layout Comparison: 1Z Engine Control Units Quote
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 19-10-2026, 5:54.
Jens 16syncro
Post28-07-2009, 10:48    Subject: PIN Layout Comparison: 1Z Engine Control Units Quote
wolfi_b wrote:
Did the 1Z engine in the Audi 80 have a throttle valve (air mass meter)?
I've only seen those on the 5-cylinder TDIs (AAT and AEL).
Are you sure about that?
wolfi_b
Post28-07-2009, 12:08    Subject: PIN Layout Comparison: 1Z Engine Control Units Quote
Yes, absolutely, the old 1Z engine with 182 Nm of torque and the potentiometer-controlled injection pump has an airflow meter.
I also have something like that icon_wink.gif.
1993 Audi 80 B4 1Z
Translated on 19-10-2026, 5:55.
Jens 16syncro
Post28-07-2009, 12:46    Subject: PIN Layout Comparison: 1Z Engine Control Units Quote
Up to which production year was the air mass meter used in the 1Z model?
wolfi_b
Post28-07-2009, 12:57    Subject: PIN Layout Comparison: 1Z Engine Control Units Quote
Starting with the 1994 model year, the cars were equipped with a mass airflow sensor, an HDK fuel pump, a different engine control unit, and a smaller turbocharger.
1993 Audi 80 B4 1Z
No new posts Which engine control units are compatible with the Passat... On-Board Diagnostics (OBD)
No new posts PIN Assignment Comfort Control Unit On-Board Diagnostics (OBD)
No new posts ECU Pinout: Wiring Diagrams and Information On-Board Diagnostics (OBD)
No new posts 12V Socket Wiring: Pinout and Connections Diesel Engine Technology
