I'm having a problem with an Audi A6, type B4, with a 2.5-liter diesel engine...
We were driving on the highway with an empty trailer and wanted to overtake a truck...
While accelerating, the engine suddenly stopped increasing in RPM, didn't take any fuel (diesel), and then simply stalled and wouldn't restart.
We have now read the error codes from the system.
First, the error message related to the engine mount (1375) appears there.
Here are three questions about it:
Can these things be measured?
Does the engine stop starting if a motor mount is broken? (I can't believe that...)
Can I simply unplug the cables to trick the electronics?
Then there was also something about a diesel pump, code 1318.
Then again, 1318 with a communication failure...
00628
and something else about the diesel pump...
We then cleared the error memory.
The only parts that were returned were the engine mount and the mass airflow sensor.
Are there going to be any more errors?
The car, of course, doesn't start... Otherwise, there wouldn't be a post about
I just disconnected a diesel line from an injector and tried to start the engine. Diesel is coming out, and I don't think it's a small amount... However, I don't know if the pressure is high enough to push the fuel through the injector... (I have no experience with diesel engines...)
We would be very grateful for any help you can provide!
The current error report (excluding items with zero errors):
VAG-COM Version: Release 303.1
Chassis Type: 4B - C5 Audi A6.
Scan: 01, 02, 03, 08, 15, 16, 17, 35, 36, 37, 45, 55, 56.
Address 01: -------------------------------------------------------
Controller: 4B0 907 401 H
Component: G00AG D33
Coding: 01001
Shop #: WSC 02325
1 Fault Found:
01375 - Valves for Engine Mounting: Stage 1.
38-10 - Output will not switch or short to B+ - Intermittent.
Readiness: Not applicable.
Address 02: -------------------------------------------------------
Controller: 4B0 927 156 B
Component: AG5 01V 2.5L TDI RdW 8915
Coding: 00000
Shop Number: WSC 00000
1 Fault Found:
18169 - Shift Lock Solenoid (N110): Short to ground.
P1761 - 35-10 - - - Intermittent
Skipping Address, 15 Airbags.
Address 45
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00002
Shop #: WSC 02325
2 faults found:
01380 - Alarm triggered by Anti-Theft Sensor: Rear Left.
35-00 - -
01381 - Alarm triggered by Anti-Theft Sensor: Rear Right.
35-00 - -
Address 56
Controller: 4B0 035 186
Component: Radio 0001
Coding: 00115
Shop #: WSC 02325
1 Fault Found:
00854 - Radio display output in dashboard panel.
49-10 - No Communications - Intermittent.
End -------------------------------------------------------
