C220 CDI: Rattling Noise on Startup
Maschine
Post06-02-2003, 16:32    Subject: C220 CDI: Rattling Noise on Startup Quote
I have a '99 C220 CDI. This morning, I tried to start it, but it wouldn't start. When I try to start it, I hear a rattling or clattering noise. Can anyone help me with this?
Translated on 28-09-2026, 2:27.
Michael II
Post06-02-2003, 16:43    Subject: C220 CDI: Rattling Noise on Startup Quote
If the rattling sound is coming from the KAT unit, it's possible that the monolith has become detached and is blocking the KAT.
Tschüss
Michael II
Translated on 28-09-2026, 2:28.
Maschine
Post06-02-2003, 17:01    Subject: C220 CDI: Rattling Noise on Startup Quote
It seems to be coming from the direction of the clutch, but the clutch pedal feels normal and can be pressed as usual.
Markus H.
Post06-02-2003, 17:47    Subject: C220 CDI: Rattling Noise on Startup Quote
Perhaps the starter motor isn't engaging properly, or there might be a problem with the power transmission.
Translated on 28-09-2026, 2:29.
Gerrit
Post06-02-2003, 21:36    Subject: Engine Noise: Troubleshooting & Solutions Quote
hello,
I also think the starter motor is likely the culprit. Your starter probably has a planetary gear system that can break and then produce noises like that. (Have you ever tried starting it by pushing? Does it work then without the strange noise?) Of course, it's difficult to diagnose a noise that you can't hear. That's why my suggestion is to record the noise and upload it as an MP3 file so we can listen to it.
Gerrit.
Back to top Profile PM Email
OM611
Post06-02-2003, 22:32    Subject: C220 CDI: Rattling Noise on Startup Quote
Hello machine,
I don't think the starter is the only likely culprit. Faults can also overlap or occur in quick succession as a result of each other. If you're sure that your machine (or engine, strange name - you're probably much more than that...) has the basic prerequisites for starting (e.g., battery voltage, control signals), you need to listen carefully to pinpoint the source of the noise. If the starter sounds normal, as far as you can tell from the noise, things will become more complicated. Your engine may not have a dual-mass flywheel, but perhaps a clutch spring is broken and rattling a bit... You need to better localize the noise!
Translated on 28-09-2026, 2:31.
Maschine
Post07-02-2003, 8:31    Subject: C220 CDI: Rattling Noise on Startup Quote
Thank you for your suggestions. The starter motor engages normally. The engine turns over normally. Regarding the OM 611 engine, if a clutch plate spring were broken, the engine would start, but it's not starting. The noise (a metallic clanging sound) seems to be coming from the clutch bell.
Translated on 28-09-2026, 2:32.
gaspedaluser
Post10-02-2003, 10:51    Subject: C220 CDI: Rattling Noise on Startup Quote
Hello machine,
Are you sure the preheating system is working properly?
Perhaps that unusual sound seems strange to you simply because you haven't heard it for so long before! A diesel engine makes a bit of noise, that's normal!
Karma: +807 / -0   Thank you, like it!
Post10-02-2003, 11:30    Subject: Clutch Bell OT Sensor Quote
Since I'm completely unfamiliar with the C220, this is just a shot in the dark: Could the OT (output transistor) sensor on the clutch bell have disintegrated, with pieces falling inside (and now rattling around)?
Does the C220 even have a knock sensor?
It would be a good idea to have the error codes read now. Perhaps you could borrow a suitable device for that?
Translated on 28-09-2026, 2:33.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts Starter Motor: RPM to Start Engine On-Board Diagnostics (OBD)
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
No new posts ESP VP37 Removal: AEL Engine (A6 2.5 TDI) Diesel Engine Technology
No new posts Golf TDI: Stuttering When Coasting to a Stop Diesel Engine Technology
