Catalytic Converter Error Code 16804: Low Efficiency
Sledge
Post21-02-2010, 16:37    Subject: Catalytic Converter Error Code 16804: Low Efficiency Quote
Hello everyone icon_smile.gif.
Yesterday I diagnosed a Fabia 1. What could be the cause of this error...? Could it really be the catalytic converter? I don't quite understand what "Bank 1" means... this is a 3-cylinder engine. Normally, only the lambda sensors monitor the system at this point, or is there another sensor on the catalytic converter?
Apparently, repairing it isn't cost-effective... (according to the workshop).
Address 01: Engine, Label file: RKS\03D-906-032-AWY.lbl
Part number: 03D 906 032 A.
Component: 1.2L/2V SIMOS3 00HS1501
Coding: 00031
Operating number: WSC 13765
TMBPW46Y633847528 SKZ7Z0C2016994
"One error found:"
16804 - Catalytic converter system; Bank 1: Effect too low.
P0420 - 35-00 - -
Readiness: 0000 0000
"edited by guste100: Title changed for clarity."
Translated on 14-08-2026, 10:05.
Post21-02-2010, 19:06    Subject: Catalytic Converter Error Code 16804: Low Efficiency Quote
The 3-cylinder engine has only 'one bank,' meaning all three cylinders are arranged side by side.
I'm not sure if anything other than the KAT could be responsible for the error message.
Translated on 14-08-2026, 10:07.
Post21-02-2010, 19:29    Subject: Catalytic Converter Error Code 16804: Low Efficiency Quote
Does the engine consume (a lot of) oil?
Translated on 14-08-2026, 10:08.
Sledge
Post21-02-2010, 20:24    Subject: Catalytic Converter Error Code 16804: Low Efficiency Quote
Hi!
According to my information, the engine doesn't consume excessive oil, and it has never been overfilled with that "black gold." It has covered over 192,000 kilometers and looks quite "honest"... almost as if someone spilled some oil on it at some point. However, it could also be that the valve cover gasket is leaking slightly.
Which sensor is this "error" actually registered by? Perhaps the measurement value is corrupted?
Post21-02-2010, 20:34    Subject: Catalytic Converter Error Code 16804: Low Efficiency Quote
P0420 is an OBD2 standard error code that indicates a problem with the catalytic converter or a leak between the engine and the catalytic converter.
The entire system is normally monitored using two lambda sensors: one before and one after the catalytic converter.
There's plenty of reading material here: http://de.lmgtfy.com/?q=p0420
Translated on 14-08-2026, 10:10.
schrauber2904
Post22-02-2010, 20:03    Subject: Catalytic Converter Error Code 16804: Low Efficiency Quote
This error is reported by the oxygen sensor after the catalytic converter. It measures the effectiveness of the catalytic converter.
It's possible that your flexible exhaust pipe is defective. Does the car sound different coming from the exhaust than usual (a bit louder and more muffled)?
bloodhound1989
Post28-02-2010, 21:02    Subject: Catalytic Converter Error Code 16804: Low Efficiency Quote
A relative of mine had a similar issue with the engine's memory. It happened in a Kia Sorento. In his case, the engine would sputter and stall when it was under heavy load. Eventually, it turned out that the oxygen sensor (lambda probe) was defective.
Translated on 14-08-2026, 10:11.
CheBu
Post04-03-2011, 12:11    Subject: Catalytic Converter Error Code 16804: Low Efficiency Quote
schrauber2904 wrote:
This error is reported by the lambda sensor after the catalytic converter. It measures the effectiveness of the catalytic converter.
It's possible that your flexible pipe is defective. Does the car sound different coming from the exhaust than usual (a bit louder and more muffled)?
May I chime in on this old topic?
The broken flex pipe is located behind the second oxygen sensor (lambda sensor) on my car.
Could that still be related to the error?
Thank you very much and best regards.
Stefan.
Translated on 14-08-2026, 10:12.
No new posts P0420 - Catalytic converter system, Bank 1, efficiency to... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Ibiza 6L error code 16415 - Bank 1, Sensor 1; Heater... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T6, rear shock absorbers - replacement / weak performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts POLO 9N Catalytic Converter System - Insufficient Effecti... Gasoline Engine Technology
No new posts DPF error - 19226 - Particle filter, bank 1, P2002 Diesel Engine Technology
No new posts Reduction system, bank 1 / SCR NOx catalyst, bank 1 Diesel Engine Technology
No new posts LLK-Wirkung teilweise enträtselt? Diesel Engine Technology
