Passat TDI Speed Sensor: Problems & Solutions
Karma: +647 / -0   Thank you, like it!
Post07-07-2010, 12:28    Subject: Passat TDI Speed Sensor: Problems & Solutions Quote
Hi there.
My friend bought a facelifted 1995 Passat 35i with a 1Z TDI engine.
It doesn't have a digital odometer like I'm used to; instead, it has a good old-fashioned mechanical odometer driven by a speedometer cable.
Now the question: Is this reading normal for this TDI engine, or does it indicate a problem somewhere between the potentially existing Hall sensor and the engine control unit (ECU)?
Unfortunately, I can't physically inspect the car myself, as it's located 400km away from me.
Thank you, Rüdi.
 File size:  109.9 KB
 Viewed:  2735 times
Translated on 08-09-2026, 8:18.
Held467
Post07-07-2010, 18:09    Subject: Passat TDI Speed Sensor: Problems & Solutions Quote
is not normal.
He has a sensor in the speedometer.
Translated on 08-09-2026, 8:19.
Post07-07-2010, 18:11    Subject: Passat TDI Speed Sensor: Problems & Solutions Quote
Held467 wrote:
is not normal.
Thanks for the information, then he should develop that AI further.
moonwalker
Post23-07-2010, 12:05    Subject: Passat TDI Speed Sensor: Problems & Solutions Quote
Hello, the TDI engine in the 35I has a speed sensor located on the transmission. It has 3 pins. There's a plastic piece inside that sometimes breaks off, or the sensor itself might be defective.
Best regards, Florian.
Translated on 08-09-2026, 8:20.
Held467
Post23-07-2010, 14:20    Subject: Passat TDI Speed Sensor: Problems & Solutions Quote
moonwalker wrote:
Hello, the TDI engine in the 35I has a speed sensor on the transmission. It's a 3-pin connector. There's a plastic piece inside that sometimes breaks off. Or the sensor itself is defective.
If it doesn't have a digital counter, the sender in the speedometer is responsible for displaying the speed.
Translated on 08-09-2026, 8:21.
moonwalker
Post23-07-2010, 18:10    Subject: Passat TDI Speed Sensor: Problems & Solutions Quote
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Passat MKB AVB: Fuel Leak Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Speed Signal: Where to Find It? Diesel Engine Technology
No new posts GRA Switch and Speed Signal Diesel Engine Technology
This topic is locked, you cannot edit or reply. Speed Signal from ABS Sensors: Possible? On-Board Diagnostics (OBD)
No new posts Speed signal in PID controller: Why? Diesel Engine Technology
