Skoda Felicia: Won't Start? Troubleshooting Guide
kylie
Post14-09-2009, 9:35    Subject: Skoda Felicia: Won't Start? Troubleshooting Guide Quote
Hello User!
The car was parked in the garage without any previous sputtering or other complaints, and then it suddenly wouldn't start. The workshop said that this was likely due to...
due to a faulty glow plug fuse, but that fuse is fine.
*correct fuel has been filled.
'Starter sounds good.'
*The engine immediately stalls when trying to start, without even sputtering or 'catching' once.
Does anyone have any other ideas about what we could try or check?
Thank you everyone, love Kylie icon_rolleyes.gif.
Translated on 01-10-2026, 21:58.
Post14-09-2009, 9:44    Subject: Skoda Felicia: Won't Start? Troubleshooting Guide Quote
The engine immediately stalls when attempting to start, without even once "catching"
What does that mean? Is the crankshaft actually turning?
Translated on 01-10-2026, 21:59.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post14-09-2009, 9:49    Subject: Skoda Felicia: Won't Start? Troubleshooting Guide Quote
Hello, do I understand correctly that the starter motor rotates until the piston passes the top dead center (TDC) position, and then the starter motor stops?
How long was the vehicle stationary after being parked?
Could the battery have collapsed?
Was ist die LL-Spannung/Anlaufspannung?
Disconnect the starter cable directly at the battery terminal and connect the ground cable to the starter motor. Measure the voltage during the starting process.
Or is the starter motor turning against the valves? Try turning it manually, or try pushing the car in 4th gear to see if it goes past Top Dead Center (TDC).
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 01-10-2026, 22:00.
luiggi
Post14-09-2009, 17:33    Subject: Skoda Felicia: Won't Start? Troubleshooting Guide Quote
Could it not also be the case that something in the vehicle (e.g., the radio, interior lighting) was still running when the vehicle was parked? And then, the next day icon_surprised.gif?
I would start by checking the battery. Maybe you can try swapping it with another vehicle. Then you'll see how it behaves when starting. Best regards.
Translated on 01-10-2026, 22:01.
kylie
Post15-09-2009, 12:40    Subject: Skoda Felicia: Won't Start? Troubleshooting Guide Quote
No, no, the battery is fine, the starter is working as it should, but the engine...
It doesn't matter.
The amount of time the vehicle had been stationary since its last use was probably only about 10 hours.
I took it to the workshop yesterday, let's see what the problem was.
Translated on 01-10-2026, 22:02.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post15-09-2009, 15:42    Subject: Skoda Felicia: Won't Start - 1.9 SDI Troubleshooting Quote
kylie wrote:
Hello User!*The engine stalls immediately when trying to start, without even "catching" once. Thank you to everyone, best regards, Kylie icon_rolleyes.gif
What do you mean by that?
Translated on 01-10-2026, 22:03.
kylie
Post16-09-2009, 9:40    Subject: Skoda Felicia: Won't Start? Troubleshooting Guide Quote
When I say 'it doesn't start,' I mean that when I try to start the engine and put it in first gear, the engine doesn't even turn over once; it immediately stalls. Perhaps it's also because the manual suggests trying to start the engine in second gear?
Conclusion: The workshop called today and said it was because all 4 glow plugs were faulty.
'were defective, and this old pre-combustion chamber engine requires one to be able to start.'
Best,
Kylie
Translated on 01-10-2026, 22:04.
Post16-09-2009, 9:51    Subject: Skoda Felicia: Won't Start? Troubleshooting Guide Quote
Now I think we've reached the point where you owe us real information if you expect anything from us.
Naturally aspirated engine or direct-injection engine?
Stalling when starting up??? Is it mechanically blocked? First gear and walking pace? What is the starter motor doing?
I'm truly sorry, but even after reading a lot of text, I don't understand what you mean at all.
Translated on 01-10-2026, 22:05.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post16-09-2009, 11:07    Subject: Skoda Felicia: Won't Start? Troubleshooting Guide Quote
S.C. direct injection?? Or what?
Translated on 01-10-2026, 22:06.
Post16-09-2009, 12:16    Subject: Skoda Felicia: Won't Start? Troubleshooting Guide Quote
Whatever a TDI without a turbo is, it's an SDI, so it has nothing to do with pre-combustion chambers.
kylie
Post17-09-2009, 6:28    Subject: Skoda Felicia: Won't Start? Troubleshooting Guide Quote
* Grund lt. Werkstatt waren 4 defekte Glühkerzen (186€ incl. Arworking hours o.O)
(I'm glad it's done; it's a real pain to change these on a Felicia.)
(the thing about the pre-chamber, the workshop told me icon_sad.gif lol).
* warum ich ihn nicht anrollen konnte ist mir rätselhaft (vlt. war der 1. (Tempo too low)
Thank you again to everyone for your commitment, but it's working again...
Best,
Kylie
Translated on 01-10-2026, 22:07.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine won't start, cranks after start attempt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda won't start: Troubleshooting guide. Diesel Engine Technology
No new posts VCDS does not recognize Skoda Octavia; Gateway not supported On-Board Diagnostics (OBD)
No new posts Car won't start, lights not working Diesel Engine Technology
This topic is locked, you cannot edit or reply. Skoda Fabia 6Y: Charging indicator light not illuminating... Electrical Systems, Vehicle Electronics, Multimedia
