V6 TDI ECU Replacement/Swap
35i-299
2004 Volkswagen Passat Consumption
Post02-10-2009, 10:30    Subject: V6 TDI ECU Replacement/Swap Quote
Enjoy your meal...
Short question for the engine control unit specialists:
Is it possible to drive a training course (STG) from the AKE within the BDH?
Apart from the adjustments to the WFS and AI.
Background:
My colleague has an Audi A6 Allroad AKE with an *** tuning that increases the power to 204 hp and torque to 410 Nm.
Now the car is a total loss...
And I could get the engine control unit (ECU) at a reasonable price.
"MFG" stands for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English. It is a common way to end a formal letter or email.
96´Passat 35i TDI AFN Syncro
Umbau auf 4-Motion
04´Passat 3BG V6 TDI 4-Motion
Translated on 15-08-2026, 1:55.
Post02-10-2009, 12:12    Subject: V6 TDI ECU Replacement/Swap Quote
AKE and BAU engines use the same fuel injection pump. However, the BDH engine has its own unique fuel injection pump. This means that the engine control unit (ECU) and the fuel pump control unit might not be compatible with each other. I would simply try connecting the ECU and see if it works.
Translated on 15-08-2026, 1:56.
Amando
Post08-10-2009, 19:31    Subject: V6 TDI ECU Replacement/Swap Quote
If the AKE control unit doesn't fit your vehicle, please let me know how much it costs!
Ideally, I would know the numbers that are on the control unit beforehand.
Translated on 15-08-2026, 1:57.
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AAZ swap Diesel Engine Technology
No new posts MSG Alternatives: Reviews & Experiences On-Board Diagnostics (OBD)
No new posts AC Compressor Replacement: Save Money Now! Transmission, Chassis, Body & Interior
No new posts Water pump replacement? Diesel Engine Technology
