VW Sharan Diagnostic Connector
sasatdi
Post10-02-2003, 14:58    Subject: VW Sharan Diagnostic Connector Quote
Hi everyone!
I drive a Sharan TDI 7M, manufactured in October 2001.
I put together the interface using the 'OK' components and the appropriate cable.
Upon closer examination of the diagnostic connector in the vehicle, a different pin configuration was identified. The following pins are connected: 3, 4, 5, 6, 7, 14, and 16. However, in the picture of the connector, pin 15 appears to be connected.
Is that why the thing isn't working? Or is the device not compatible with the car's system?
Help!!!
http://www.planetfall.com/~jeff/obdii/schematic_b1.pdf
Best regards, Alex.
Translated on 17-09-2026, 3:53.
Post10-02-2003, 15:13    Subject: Basically... Quote
...if you have assembled the circuit according to http://www.dieselschrauber.de/diagnose.html, then you are in the right place with your question.
Otherwise: Ask where you got your circuit diagram from.
Pin 15 of the ODB socket is the L-line, which is probably no longer used in newer vehicles. This should not affect the function of the adapter.
Translated on 17-09-2026, 3:54.
sasatdi
Post20-02-2003, 14:34    Subject: VW Sharan Diagnostic Connector Quote
Hi!
'I apologize for my typos.'
I also figured out the problem with the adapter.
Wrong COM cable.
What I would also like to know is what the individual measurements mean.
For example, where can I turn the cruise control on and off?
Is there a table somewhere?
Best regards, Alex.
PS: The two circuits are identical.
Translated on 17-09-2026, 3:55.
Post20-02-2003, 14:54    Subject: VW Sharan Diagnostic Connector Quote
sasatdi wrote:
What I would still like to know is what the individual measurements mean,
http://www.dieselschrauber.de/Solldaten_Main.html
Please search for "login" or "logincode" in the TDI error database.
Translated on 17-09-2026, 3:56.
No new posts Doku Sharan 7M9, Engine Noises at MKB ANU Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB ANU Engine Noises: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Workshop Action: Sharan, Mass Flow Meter Connection Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diagnostic Connector A6 Diesel Engine Technology
No new posts Diagnostic connector Diesel Engine Technology
No new posts Diagnostic plug for old 1Z engine Diesel Engine Technology
No new posts Looking for a diagnostic tool? Diesel Engine Technology
