Skoda Octavia 1.9: Specs, Problems, & More
testraucher
Post28-09-2009, 15:16    Subject: Skoda Octavia 1.9: Specs, Problems, & More Quote
Hello, my dear Skoda enthusiasts.
Okay, I'm having a problem with my Skoda Octavia, 1.9 TDI, 66 kW, manufactured in 2001, with 250,000 km on the odometer.
Zahnriemen neu belegt. Wasserpumpe neu. Kraftstofffilter neu. ESP neu. Luftmengenmesser neu. Air filter replaced.
Problem description: Before replacing all the parts, the performance dropped from 190 km (miles) to 160 km (miles). At a constant engine speed, for example 100 km (miles), the diesel consumption shows erratic readings... 28.6 liters, 31.4 liters, etc. Furthermore, small air bubbles are visible in the hose from the fuel filter. The ESP fuses have been replaced. The car accelerates well up to 3rd gear. No smoke is visible during driving. Cold starts are very good. No turbo noises can be heard. A visual inspection of the turbo shows everything to be okay.
"The car suddenly lost power while I was driving on the highway... I would appreciate it if someone could help me."
Sure, here's the translation:
"Please don't criticize my German."
Best regards, test smoker.
Are the glow plugs possibly faulty, or is it the turbocharger pressure sensor??? icon_biggrin.gif
Translated on 12-09-2026, 9:20.
Post28-09-2009, 15:31    Subject: Skoda Octavia 1.9: Specs, Problems, & More Quote
The engine control unit (ECU) will tell you why it's running in limp mode; you just need to ask it.
Actually, you could have skipped this answer if you had read the page after registering...
Translated on 12-09-2026, 9:22.
testraucher
Post28-09-2009, 15:37    Subject: Skoda Octavia 1.9: Specs, Problems, & More Quote
"First of all, thank you. I'm not a professional, I've just read a lot here. You make it sound so easy. I just wanted to hear what an expert has to say. So, the error must be stored somewhere, right? Could you also tell me, on average, how much a used control unit costs? As I said, I'm not an expert in this area. Thanks in advance."
Translated on 12-09-2026, 9:23.
testraucher
Post28-09-2009, 15:41    Subject: Skoda Octavia 1.9: Specs, Problems, & More Quote
Note: Since I can't read the vehicle's diagnostic system myself, I have to always believe what the mechanic tells me. I've also heard that some errors might not be recorded. Best regards, testraucher.
Post28-09-2009, 15:45    Subject: Skoda Octavia 1.9: Specs, Problems, & More Quote
Translated on 12-09-2026, 9:24.
Amando
Post20-10-2009, 22:12    Subject: Skoda Octavia 1.9: Specs, Problems, & More Quote
I would NEVER just replace a control unit wholesale if an error occurs after the repair (assuming I understood correctly?).
"Where are you from? Definitely the first step would be to have the error codes read. If there's nothing stored there, which I doubt, then we'll start looking for the problem."
"However, having air in the intake line of the ESP is something that shouldn't happen. Perhaps there's a leak in the connection at the filter (specifically the return line), which is drawing in air and could eventually prevent it from working properly, as the engine would then be lacking fuel. Just a quick thought to consider!"
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf IV / Octavia 1 Water ingress at the doors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 1Z5 RS Cornering Light On-Board Diagnostics (OBD)
No new posts Skoda Octavia ABS Fault Transmission, Chassis, Body & Interior
No new posts Skoda Octavia 5E battery coding Electrical Systems, Vehicle Electronics, Multimedia
No new posts Skoda Octavia Starting Problems: Troubleshooting Guide On-Board Diagnostics (OBD)
