Measuring VCDS compression?
chriskross
Post18-10-2009, 14:02    Subject: Measuring VCDS compression? Quote
"Hi, can you measure cylinder compression with VCDS? According to this thread, it should be possible."
[Link to Motortalk]
Can someone tell me how to do this with VCDS?
best regards, chris
A6 AFB
A6 BRE DPF
Translated on 12-07-2026, 4:38.
Post18-10-2009, 14:05    Subject: Re: Measuring compression with VCDS? Quote
chriskross wrote:
kann mir jemand sagen wie das mit vcds geht?
Not at all icon_smile.gif.
There are no cylinder pressure sensors that can be queried, and the sampling rate via diagnostics is likely too low to meaningfully evaluate the onboard voltage/current draw of the starter motor.
Translated on 12-07-2026, 4:39.
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Measuring boost pressure with VCDS RKS 12.12 Gasoline Engine Technology
No new posts AFB Compression: Explained and Optimized Diesel Engine Technology
No new posts Oil Temperature: Where to Measure It? Diesel Engine Technology
No new posts Measuring boost pressure On-Board Diagnostics (OBD)
