Thanks for the information. Where is the sensor located?
From the back, access to/of the control panel. Discreetly accessible.
There's another peculiarity: when you turn the ignition on without starting the engine, you can hear a kind of whistling sound coming from the engine compartment.
Does anyone know about this and what the cause might be?
Yes.
Is there perhaps a connection to the display issue?
Definitely not!
Only when the sound is missing would I start to worry
The noise is coming from the DK (likely a device or component). It's electrically controlled by the AXR and powered with a voltage that is modulated using Pulse Width Modulation (PWM). Under certain conditions, this can be heard as a whistling sound.
