D+ Terminal on Alternator
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
blackblizzard
Post01-02-2010, 12:52    Subject: D+ Terminal on Alternator Quote
Hello!
For what purpose is the D+ terminal actually needed on the alternator? Actually, B+ and B- should be sufficient, the rest is handled by the controller.
Best regards
Post01-02-2010, 13:01    Subject: D+ Terminal on Alternator Quote
blackblizzard wrote:
Actually, B+ and B- should be sufficient, the rest is taken care of by the controller.
I don't think so.
What is D+?
D+ (Dynamo Plus) = Excitation coil/Charging control light, also Class 61
blackblizzard
Post01-02-2010, 13:33    Subject: D+ Terminal on Alternator Quote
And how does this work with the excitation coil? I have always thought that the controller "manages" this.
Post01-02-2010, 13:42    Subject: D+ Terminal on Alternator Quote
And how does this exciter coil work? I have always thought that the controller {controls}
Yes, he does. However, he needs to know that he should be aiming for something. And that's what he says, how it should be, D+.
blackblizzard
Post01-02-2010, 14:16    Subject: D+ Terminal on Alternator Quote
And how should that work, or how and where is the D+ connected?
Best regards
Post01-02-2010, 14:42    Subject: D+ Terminal on Alternator Quote
Please follow the link in this thread:
/viewtopic.php?t=22582&highlight=120a
blackblizzard
Post01-02-2010, 15:20    Subject: D+ Terminal on Alternator Quote
Thank you!
So, man könnte also D+ eigentlich an B+ hängen, dann würde die Lima genau so funktionieren, nur die Ladekontrolleuchte wäre dann ohne Funktion??
Best regards
scroll tdi
Karma: +5 / -3   Thank you, like it!
Post01-02-2010, 16:09    Subject: D+ Terminal on Alternator Quote
Your alternator does not have a permanent magnet installed. Therefore, the exciter coil needs a voltage. Without the excitation coil, no electrical energy is generated.
With the bridge, it only works if there is still some residual magnetism in the excitation coil.
blackblizzard
Post01-02-2010, 16:30    Subject: D+ Terminal on Alternator Quote
I already know that the exciter coil is not a permanent magnet. That's why I'm asking: What if I simply connect the D+ terminal of the alternator to the B+ terminal? Then, current flows through the field coil, and the alternator must also supply power.
Post01-02-2010, 18:04    Subject: D+ Terminal on Alternator Quote
Tell me, what your problem is.
scroll tdi
Post01-02-2010, 18:11    Subject: D+ Terminal on Alternator Quote
What came first, the egg or the chicken?
As long as there is no magnetic field, there will be no voltage. Therefore, there will be no voltage for the motor. And therefore, the alternator will not work with the bridge.
blackblizzard
Post01-02-2010, 18:18    Subject: D+ Terminal on Alternator Quote
I'm only interested in the function of the alternator - specifically, the D+ Kemme.
D+ Depends on the ignition being on, meaning that when the ignition is on, current flows to the excitation coil.
The same effect would also occur if D+ and B+ were connected - however, with a stationary vehicle, the battery would eventually drain.
Is that correct?
AllesScraubermitWerkzeug
Karma: +0 / -1   Thank you, like it!
Post01-02-2010, 18:35    Subject: D+ Terminal on Alternator Quote
Good question...I know exactly what you mean. Yes, the child has only a different name for the purpose of identification.
D+ is connected to the KL.30 (B+). D+ is used solely to identify the wire that supplies the excitation voltage to the alternator.
In principle, Kl.85 on a relay (the copper coil) is simply switched B+ or Kl.15... this is only for easier identification... because everything in a car is B+ or B-, but simply wired differently.
Mechaniker ohne eigenes Werkzeug kann nichts werden.
scroll tdi
Post01-02-2010, 19:42    Subject: D+ Terminal on Alternator Quote
My focus is solely on the function of the alternator - specifically on the D+ terminal.
Is that correct?
must measure whether there is voltage at B+ when the car is stationary. icon_wink.gif
yes, if that's the case, then the battery will drain...
blackblizzard
Post01-02-2010, 20:38    Subject: D+ Terminal on Alternator Quote
No new posts AFN Alternator: Connect Terminal W to 120A Diesel Engine Technology
No new posts Terminal 15, engine compartment / central electronics box Electrical Systems, Vehicle Electronics, Multimedia
No new posts What are the uses of different connectors? Diesel Engine Technology
No new posts Terminal 58d - Short circuit to ground Electrical Systems, Vehicle Electronics, Multimedia
