Oil Consumption Spikes Suddenly!?
Hoti
Post08-05-2002, 19:20    Subject: Oil Consumption Spikes Suddenly!? Quote
Hello.
I drive a car with a 90 horsepower TDI engine, and it has almost 170,000 kilometers on the odometer.
'Recently, I've noticed that the car is using a lot of oil.'
It's not leaking oil anywhere.
A colleague told me it might be a problem with the head gasket.
Could that be the reason? If not, what else could it be due to?
Translated on 30-07-2026, 23:05.
Michael II
Post08-05-2002, 19:41    Subject: Oil Consumption Spikes Suddenly!? Quote
The causes of oil consumption can be varied.
Piston rings.
- Bearing damage on the turbocharger.
- Valve stem seals.
Have you ever tested the compression?
How much oil does it consume?
Tschüss
Michael II
Translated on 30-07-2026, 23:06.
Hoti
Post09-05-2002, 16:57    Subject: Oil Consumption Spikes Suddenly!? Quote
I have no idea how much, but I only realized it this week.
Definitely more than 1 liter per 1000 kilometers.
Otherwise, I don't know anything about engines, but if they...
Compression is not okay; shouldn't one notice that!?
The car is behaving normally, and so far it has been working very well.
'It didn't use any oil, so I rarely checked the oil level.'
watched. Only twice in the past week. The first time was...
The stock was below the minimum level, and it has been replenished as required.
Upon checking again, the reading was back at its minimum value.
Translated on 30-07-2026, 23:07.
Post09-05-2002, 17:21    Subject: Bad Sound? Troubleshooting & Solutions Quote
Hi.
Over 1 liter / 1000 km is more than what the engines are maximally allowed to consume from the factory, and therefore indicates a defect.
You can also perform a preliminary compression test yourself; the instructions are described on Rainer's website in the used car tips section.
If it doesn't produce any serious results, it could be due to the causes described by Michael, which are all quite unpleasant (because they are expensive to repair) icon_sad.gif icon_sad.gif.
Translated on 30-07-2026, 23:09.
No new posts VW T5, 2.0 BiTDI, excessive oil consumption Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: High oil consumption, AFB and AKN engines Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K9, MKB AGP, Increased oil consumption Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel consumption increases, engine power decreases Diesel Engine Technology
No new posts [IBIZA 6K] The sunroof suddenly operates automatically... Transmission, Chassis, Body & Interior
No new posts Golf VI Cabrio Warning message Fuel tank appears only once Electrical Systems, Vehicle Electronics, Multimedia
No new posts Biodiesel: Answers from the Top Experts Diesel Engine Technology
