Adjusting the {ELECTRO_SERVO} in the 3C/1K setup?
Post01-12-2009, 10:37    Subject: Adjusting the {ELECTRO_SERVO} in the 3C/1K setup? Quote
Can the electromechanical servo be adjusted in the 3C/1K to provide more assistance?
In the labels, I didn't find anything.
My new steering column STG and the associated steering angle learning and servo end stop learning make my car's steering feel stiffer. And as a city sphere, it should be a bit more impersonal icon_smile.gif
Golf:
Address 44: Steering Aid Label file: RKS\1Kx-909-14x.lbl
Part Number: 1K1 909 144 M
Part: EPS_ZFLS Class.069 H08 1901
Operating Number: WSC 39799 133 89844
Passat:
Part Number: 1K1 909 144 L
Part: EPS_ZFLS Class 136 H07 1806
Operating Number: WSC 02069 000 90108
Post01-12-2009, 11:05    Subject: Adjusting the {ELECTRO_SERVO} in the 3C/1K setup? Quote
Maybe the wrong suspension type or spring range was chosen?
http://de.openobd.org/vw/golf_1k.htm#44
Post01-12-2009, 11:11    Subject: Adjusting the {ELECTRO_SERVO} in the 3C/1K setup? Quote
Oho... The Passat is allegedly "learning-worthy" in aspects that are not mentioned in the Golf.
For the Passat, no PR adjustments are needed.
If the Golf also has learning values, and the G85 and end position have been forgotten, then this is probably already an explanation for the different feeling when steering.
Post01-12-2009, 11:17    Subject: Adjusting the {ELECTRO_SERVO} in the 3C/1K setup? Quote
Hm ... Does the Passat have a different steering gear? So, mehr oder weniger, von Anschlag bis Anschlag?
Post01-12-2009, 11:24    Subject: Adjusting the {ELECTRO_SERVO} in the 3C/1K setup? Quote
I need to check that first...
Post02-12-2009, 21:04    Subject: Adjusting the {ELECTRO_SERVO} in the 3C/1K setup? Quote
The golf cannot be adjusted to channel 01.
There are only 2, 3, and 4.
Post08-12-2009, 21:03    Subject: Adjusting the {ELECTRO_SERVO} in the 3C/1K setup? Quote
Okay
Adapting is not.
But they are adapted - see MWB 008
Golf Characteristics Index 69 Normal 3
Passat, Characteristic Index 136, Normal 6
EDIT:
I just noticed that the characteristics are not listed in MWB 008, but actually in the part identification:
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adjust Consumption Display Diesel Engine Technology
No new posts Customizing WFS2? Transmission, Chassis, Body & Interior
No new posts TDI Tuning: MSG & AI Adjustments for VAG 115PS On-Board Diagnostics (OBD)
No new posts ASZ Drehmomentkurve anpassen? Diesel Engine Technology
