hoepfelchecker
13-12-2009, 11:43 Subject: Car Won't Start? Troubleshooting Guide |
...Hello.
I installed an aftermarket heated seat system, including the entire wiring harness, and now the engine won't start... I have a 1.9 diesel engine... I'm desperate... what could be the problem?
...there is no error message...
...I just noticed that the glow plug unit isn't working before I try to start the engine... it can't be due to the recent modifications, right???
Translated on 17-09-2026, 0:46.
Joined: 04/12/2002 Posts: 18134 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
13-12-2009, 11:46 Subject: Car Won't Start? Troubleshooting Guide |
Okay, have you checked the basics? Is the battery dead? Does the interior lighting turn off when you try to start the car?
Quote: | | ...I just noticed that the glow plug unit isn't turning on before you start the engine | .
More likely, the battery is drained if the starter motor isn't turning. I think your seat heater might also be heating up while the car is stationary.
Translated on 17-09-2026, 0:47.
Profile PM WWW Garage |
hoepfelchecker
13-12-2009, 11:49 Subject: Car Won't Start? Troubleshooting Guide |
No, none of that is the case... as I said, the preheating unit isn't activating. Could it be related to terminal 30, from which I took the positive connection for the seat heater?
Translated on 17-09-2026, 0:48.
13-12-2009, 11:56 Subject: Car Won't Start? Troubleshooting Guide |
Then you should probably provide some more information about the vehicle, the modifications, and things that have already been tested.
hoepfelchecker
13-12-2009, 12:16 Subject: Car Won't Start? Troubleshooting Guide |
...is a 4-door Golf TDI...
Yesterday, I installed a wiring harness for the seat heaters, and since then, the car won't start because the glow plug unit isn't activating when I turn the ignition key.
Translated on 17-09-2026, 0:49.
13-12-2009, 12:25 Subject: Car Won't Start? Troubleshooting Guide |
I assume this is only indirectly related to the wiring harness installation. You must have connected the cables to the potential distribution block in the fuse box, right? If so, I would say that relay 109 is faulty and is no longer switching due to your tinkering. Relay 109 is known for having cold solder joints, and is often a source of errors. Just try bridging the load circuits of this relay; if it then works, you'll know what the problem is. If it doesn't work, you can rule it out.
Translated on 17-09-2026, 0:50.
Profile PM Garage |
hoepfelchecker
13-12-2009, 12:39 Subject: Car Won't Start? Troubleshooting Guide |
...this relay isn't located in the fuse box, but rather in a socket underneath the steering wheel, where I screwed the positive wire to terminal 30, right?
13-12-2009, 12:45 Subject: Car Won't Start? Troubleshooting Guide |
hoepfelchecker wrote: | | ...this relay isn't located in the fuse box, but rather in a socket underneath the steering wheel, where I screwed the positive wire to terminal 30, right? |
Yes, that's what I mean. On the relay holder, there are also fuses. I expressed myself a little clumsily above.
Translated on 17-09-2026, 0:51.
Profile PM Garage |
hoepfelchecker
13-12-2009, 12:48 Subject: Car Won't Start? Troubleshooting Guide |
...and what should I do next?
So, is it not at terminal 30 where I'm connecting the positive wire, or what?
Translated on 17-09-2026, 0:52.
13-12-2009, 12:52 Subject: Car Won't Start? Troubleshooting Guide |
hoepfelchecker wrote: | | ...and how am I supposed to proceed now? |
Read what I've written and do it.
Profile PM Garage |
hoepfelchecker
13-12-2009, 12:54 Subject: Car Won't Start? Troubleshooting Guide |
...hmm, yes, and how do I handle the bridging?
Translated on 17-09-2026, 0:53.
13-12-2009, 13:12 Subject: Car Won't Start? Troubleshooting Guide |
Take a piece of cable, strip the insulation from both ends, and insert it into the contacts of the load circuit. But please don't ask me now how to strip a cable.
Profile PM Garage |
schrauber2904
13-12-2009, 13:13 Subject: Car Won't Start? Troubleshooting Guide |
"Remove the relay and first check if there is voltage at terminal 30. If there is, then bridge terminal 30 to terminal 86."
13-12-2009, 13:15 Subject: Car Won't Start? Troubleshooting Guide |
schrauber2904 wrote: | | if so, then you bridge terminal 30 to 86. |
Terminal 86, according to DIN standards, is the control terminal on a relay. Terminal 87 is the load terminal. However, this is also usually indicated on the relay itself.
Translated on 17-09-2026, 0:54.
Profile PM Garage |
hoepfelchecker
13-12-2009, 13:34 Subject: Car Won't Start? Troubleshooting Guide |
Okay, I've bypassed it now, but unfortunately, that's not leading to any results either; the engine still won't start.
hoepfelchecker
13-12-2009, 13:39 Subject: Car Won't Start? Troubleshooting Guide |
...Thank you everyone, the problem is now solved... Fuse 29 was not quite properly inserted  now it's working again.
Translated on 17-09-2026, 0:55.
