PDC Control Unit Mounting Points VW Golf 4
stefouzo
Post15-12-2009, 23:05    Subject: PDC Control Unit Mounting Points VW Golf 4 Quote
I installed an aftermarket parking distance control (PDC) system on my Golf IV (from Conrad, not original). I'm quite happy with it so far, but I still need to properly install the control unit; I'm not very impressed with the adhesive pads that were included.
"For the original PDC control unit, VW offers a metal bracket that is presumably screwed onto somewhere behind the right side trunk lining. I would like to use this bracket. Does anyone know where the exact mounting points for this control unit bracket are? Maybe someone even has a photo..."
Thank you in advance!
Stefan
Translated on 26-07-2026, 5:12.
Wiesel
Post15-12-2009, 23:41    Subject: PDC Control Unit Mounting Points VW Golf 4 Quote
Hello Stefan,
Take a look at Rameder's website for the installation instructions for the G4.
Since (in the case of a corresponding electrical connection), a cable needs to be run to the parking distance control system.
It's often very well documented (at least it was with my Octavia).
Perhaps this will be helpful.
Micha
Translated on 26-07-2026, 5:13.
stefouzo
Post16-12-2009, 0:01    Subject: PDC Control Unit Mounting Points VW Golf 4 Quote
Hey, thanks for the quick reply, I wouldn't have thought of that idea myself!
The instructions for the Golf IV are also very detailed, but unfortunately, they do not cover the parking distance control (PDC) icon_sad.gif.
Translated on 26-07-2026, 5:14.
Post16-12-2009, 9:10    Subject: PDC Control Unit Mounting Points VW Golf 4 Quote
I used cable ties and felt pads (to reduce vibration noise).
stefouzo
Post27-12-2009, 15:35    Subject: PDC Control Unit Mounting Points VW Golf 4 Quote
Okay, now that I've installed the control unit with the original bracket, here's a quick update for anyone who might have the same question in the future:
The bracket is screwed onto the trunk floor under the right taillight. Unfortunately, there are no pre-installed nuts here; instead, there are only two hexagonal recesses in the body panel. This is where blind rivets are inserted, which are then set using a riveting tool (I had this done by VW because I didn't have the appropriate tool).
Overall, it's not as simple as double-sided tape (which is common with retrofit solutions), but it's a very decent solution. There's also enough space under the attached control unit to neatly organize the wiring harness.
Best regards, Stefan.
Translated on 26-07-2026, 5:16.
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steuergerät Golf 2 On-Board Diagnostics (OBD)
No new posts Airbag Control Unit VW Golf 3 On-Board Diagnostics (OBD)
No new posts 1Z Steuergerät vom Passat 35i an Golf 3 betreiben? On-Board Diagnostics (OBD)
No new posts ESP Control Unit Coding - Golf 4 4motion TDI (AJM) On-Board Diagnostics (OBD)
