VCDS: Not Compatible with Windows NT 6.1
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post21-01-2010, 21:33    Subject: VCDS: Not Compatible with Windows NT 6.1 Quote
Hi, I bought a Medion Akoya E7212. When I tried to install VCDS Release RKS 805.1 from the disc onto the hard drive, it displayed an error message. What should I do to get it to work?
Bye.
reflexsilber met.
Translated on 26-10-2026, 19:19.
Post21-01-2010, 21:38    Subject: VCDS: Not Compatible with Windows NT 6.1 Quote
Why don't you release updates? They don't cost anything, do they?
Translated on 26-10-2026, 19:20.
RedR32
Avatar-RedR32
Post21-01-2010, 21:54    Subject: VCDS: Not Compatible with Windows NT 6.1 Quote
Thanks, Rainer. I have to laugh at myself. Is the disc still needed if I use a different device, like a new laptop? I'm going to test it directly on the vehicle again.
reflexsilber met.
RedR32
Avatar-RedR32
Post21-01-2010, 22:18    Subject: VCDS: Not Compatible with Windows NT 6.1 Quote
Everything is great, thanks.
reflexsilber met.
Post21-01-2010, 23:09    Subject: VCDS: Not Compatible with Windows NT 6.1 Quote
The CD is actually only for the initial installation.
Otherwise, all software installation packages are available for download in the shop.
http://shop.dieselschrauber.de/support-downloads.php
No new posts Screenshot unter Windows erstellen und posten General Tips
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS and Windows 10: Compatibility & Setup On-Board Diagnostics (OBD)
No new posts VCDS-RKS Compatibility with Windows 8 On-Board Diagnostics (OBD)
No new posts GRA Connector Not Compatible: Troubleshooting & Fixes Diesel Engine Technology
No new posts VCDS does not recognize Skoda Octavia; Gateway not supported On-Board Diagnostics (OBD)
