1Z Engine Start Problem: Fault Found
mhernach
Post05-03-2003, 6:58    Subject: 1Z Engine Start Problem: Fault Found Quote
Okay, now it all makes sense. The starting problem wasn't due to the glow plug system, but to the injection timing!
The KW screw has come loose, and now my KW suspension is broken. The groove is worn out. This has already happened to me about 80,000 km ago. Back then, the Ford workshop spent about a week trying to find and fix the problem. Now I have to do the same thing again, as I no longer have a warranty, and nothing is covered under goodwill.
Translated on 18-09-2026, 13:39.
haehnlein
Post05-03-2003, 12:31    Subject: Engine Start Problem: Fault Found (1Z) Quote
At that time, the Ford workshop searched for the error for about 1 week and then fixed it. icon_sad.gif
First, my sincere condolences icon_question.gif. What exactly did the workshop do back then? Did they grind the KW or just replace the screw }?
Best regards, Christian.
Translated on 18-09-2026, 13:40.
mhernach
Post05-03-2003, 14:01    Subject: Engine Start Problem: Fault Found (1Z) Quote
At that time, the workshop replaced the crankshaft pulley, timing belt, timing belt, and idler pulleys. Unfortunately, there was only a 1-year warranty, and I've driven 80,000 km since then.
But this time, I'm going to do it myself, and that will definitely make it last. I read somewhere that you can grind down the KW (presumably referring to a component), if it's possible or necessary.
Best regards, Mike.
Translated on 18-09-2026, 13:42.
haehnlein
Post05-03-2003, 14:10    Subject: Engine Start Problem: Fault Found (1Z) Quote
mhernach wrote:
I read that you can use a slip joint, if it's possible or necessary.
Best regards, Mike
Hi Mike,
is guaranteed necessary icon_exclaim.gif Don't drive it anymore icon_exclaim.gif icon_exclaim.gif The stupid workshop seems not to have replaced the KW screw....look here:
http://home.arcor.de/sgrafen/salatoel/kw_schraube/kw_schraube.html
Please check if you have the 12.9 screw installed (see link) icon_exclaim.gif.
Translated on 18-09-2026, 13:43.
mhernach
Post05-03-2003, 14:20    Subject: Engine Start Problem: Fault Found (1Z) Quote
Unfortunately, I can't access your homepage from my company's network; it's blocked. Could you please send it to me via email?
Thank you again...
Best regards, Mike.
Translated on 18-09-2026, 13:44.
No new posts Air Bubbles: Find the Root Cause & Fix It! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts EDS Regulation flawed! Found the mistake! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Starting problem 2.0 TDI BMM VW engine Diesel Engine Technology
No new posts Error 462: Troubleshooting & Solutions On-Board Diagnostics (OBD)
No new posts Central Locking Error: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts ABS Error: VW Polo (6N) 2005 EEPROM Problem On-Board Diagnostics (OBD)
