VCDS Function: Engine Control Unit (ECU) Mileage. Why is it so rare?
Go to page: 1, 2  Next
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Post31-10-2009, 17:50    Subject: VCDS Function: Engine Control Unit (ECU) Mileage. Why is it so rare? Quote
Hello.
Why is the function "read engine control unit mileage" not supported by almost any control unit? So far, I've only found it working on two vehicles. Both were Sharan models, one from 2001 and the other from 2002, both with a 1.9 TDI PD engine, MKB: AJM.
What experiences do you have, and what was it like for you in those situations?
P.S. Yesterday, I had a 2009 A4 with a 2.0 TDI CR engine. It didn't work even then. icon_confused.gif
Translated on 12-07-2026, 19:24.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post31-10-2009, 18:52    Subject: VCDS Function: Engine Control Unit (ECU) Mileage. Why is it so rare? Quote
I can read the data from the Leon and Ibiza models, but not from the Golf.
reflexsilber met.
Translated on 12-07-2026, 19:25.
Post31-10-2009, 18:56    Subject: VCDS Function: Engine Control Unit (ECU) Mileage. Why is it so rare? Quote
My Golf and T4 aren't working either.
RedR32
Avatar-RedR32
Post31-10-2009, 19:05    Subject: VCDS Function: Engine Control Unit (ECU) Mileage. Why is it so rare? Quote
Could it be due to the different VCDS versions?
Who knows more?
reflexsilber met.
Translated on 12-07-2026, 19:26.
Post31-10-2009, 22:27    Subject: Re: VCDS Function: Engine Control Unit Mileage. Why is it so rare? Quote
TDI-GTI-4-Motion wrote:
What experiences do you have, and where did things go similarly for you?
Polo 9N ASZ from 2004: available.
Ibiza Cupra TDI BUK from 2006: also works.
mullemaus
Post01-11-2009, 1:22    Subject: Re: VCDS Function: Engine Control Unit Mileage. Why is it so rare? Quote
PS. Hatte gestern nen 2009er A4 mit 2.0 TDI CR. Nicht mal da ging es. icon_confused.gif
Logisch. CR = EDC17.
What is supported? Some EDC15+16 icon_lol.gif icon_wink.gif.
Translated on 12-07-2026, 19:27.
Post01-11-2009, 2:35    Subject: Re: VCDS Function: Engine Control Unit Mileage. Why is it so rare? Quote
Okay. That explains why the 2008 Jetta didn't work. Just out of curiosity: are there any gasoline-powered models that do work?
Translated on 12-07-2026, 19:28.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post01-11-2009, 8:00    Subject: VCDS Function: Engine Control Unit (ECU) Mileage. Why is it so rare? Quote
Regarding the cars listed in my signature, the feature doesn't work on the Passat or the Sharan. I once had an Alhambra with engine code AUY where it did work. It hasn't worked on any of the other models I've ever accessed.
Passat Variant BGW 2005
DariusPolo
Post01-11-2009, 10:44    Subject: VCDS Function: Engine Control Unit (ECU) Mileage. Why is it so rare? Quote
Octavia 2002 ASV - no.
Ibiza 2003 ASZ - yes.
Alhambra 2004 ASZ - no.
A6 2003 AWX - no.
2 x Passat 2001 with AJM engine - yes.
2x Sharan 2003 ASZ - no.
Alhambra 2003 AUY - yes.
Passat 2004 (100 hp) - no.
Polo 2002 (100 hp) - no.
Translated on 12-07-2026, 19:30.
Post01-11-2009, 11:45    Subject: VCDS Function: Engine Control Unit (ECU) Mileage. Why is it so rare? Quote
My Golf ASZ from 2002 also has something against icon_sad.gif.
The bus isn't working either.
I have never had success icon_sad.gif.
Translated on 12-07-2026, 19:31.
Post01-11-2009, 13:35    Subject: VCDS Function: Engine Control Unit (ECU) Mileage. Why is it so rare? Quote
As you can see, it seems that the AJM/AUY engine actually works in almost every car and year of manufacture.
bartheho
Post02-11-2009, 21:03    Subject: VCDS Function: Engine Control Unit (ECU) Mileage. Why is it so rare? Quote
For both cars listed in my profile.
Best regards, Holger.
Passat Bj. 2014, MKB CAYC
Translated on 12-07-2026, 19:32.
Micha2005
Post09-11-2009, 22:19    Subject: VCDS Function: Engine Control Unit (ECU) Mileage. Why is it so rare? Quote
The 2005 Touran with the 2.0 BKD engine is not working.
Micha
BM
Avatar-BM
Post10-11-2009, 16:20    Subject: VCDS Function: Engine Control Unit (ECU) Mileage. Why is it so rare? Quote
Golf IV ALH 2001 --> Available/Works.
Everything else has been fine so far.
3B5 AJM
Post10-11-2009, 17:53    Subject: VCDS Function: Engine Control Unit (ECU) Mileage. Why is it so rare? Quote
BM wrote:
Alles Andere bei mir bisher nicht.
Isn't that your AJM from the signature?
Translated on 12-07-2026, 19:33.
DariusPolo
Post10-11-2009, 23:40    Subject: VCDS Function: Engine Control Unit (ECU) Mileage. Why is it so rare? Quote
Skoda Superb 2004, 130 horsepower, 5-speed manual - yes.
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Bremsflüssigkeits-MIL ohne Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 4Motion keine Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Disable Auxiliary Heater on VW Touran 1.9 TDI On-Board Diagnostics (OBD)
No new posts Log zu T4 -- Fehler 1268 + 765 tritt nur sehr selten auf Upload
No new posts "Service reminder function with VCDS" On-Board Diagnostics (OBD)
No new posts Engine Control Units with Aftermarket Support On-Board Diagnostics (OBD)
