Tuning ECU: Optimized Engine Control Unit & MFA
maxmoritz
Post13-04-2010, 17:57    Subject: Tuning ECU: Optimized Engine Control Unit & MFA Quote
Hello, I am the 'new' icon_biggrin.gif.
I've been reading here for quite some time now...
I have a 20-year-old Golf 3 TDI GTI with the AFN engine.
I recently bought a chipped engine control unit from a friend at a good price.
which he, according to his statement, had optimized with a car at either 'ertl' or 'örtl'.
The control unit is a 028 906 021 DF control unit.
The car is running okay so far; I adjusted the WFS (Warm Function Start) using VAG-COM.
Now I would like to ask how the MFA values change.
Or, to put it another way, are they still 'credible,' or does anyone know?
Anything about the tuning from the MFA?
Thank you very much.
Translated on 27-09-2026, 15:56.
Post13-04-2010, 19:56    Subject: Tuning ECU: Optimized Engine Control Unit & MFA Quote
Or, to put it another way, are they still "credible"
Yes, if the tuning was at least done technically correctly (which doesn't say anything about whether the changes are sensible or acceptable).
If it was shoddy work: no.
Translated on 27-09-2026, 15:58.
maxmoritz
Post18-04-2010, 11:47    Subject: Tuning ECU: Optimized Engine Control Unit & MFA Quote
Okay, so the company that chipped the engine control unit was *********.
I had the invoice provided to me for the purpose of registration according to §21.
Do they have any experience regarding the quality of the tuning?
How can I actually upload photos here?
Moritz
Translated on 27-09-2026, 15:59.
Post18-04-2010, 11:53    Subject: Tuning ECU: Optimized Engine Control Unit & MFA Quote
Are there any experiences regarding the quality of their tuning?
Sorry, aufgrund mangelnder Nachvollziehbarkeit von anonym gemachten Aussagen gibts hier sowas i.d. Don't break the rules.
An alternative would be to adjust the MFA (Multi-Function Display) using VCDS (if possible, on a car with an AFN engine, which is quite old; I don't recall off the top of my head whether there's a corresponding adjustment channel in the instrument cluster).
Translated on 27-09-2026, 16:00.
Post18-04-2010, 11:55    Subject: Tuning ECU: Optimized Engine Control Unit & MFA Quote
Rainer K. wrote:
I don't know off the top of my head whether there is a corresponding adjustment channel in the instrument cluster.
"Using OBD definitely won't work in this case, because the Golf III's engine control unit doesn't have a diagnostic port."
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts GRA for AGR Valve Control Unit On-Board Diagnostics (OBD)
No new posts ECU and MAF Sensor: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts Only ABS control unit??? On-Board Diagnostics (OBD)
No new posts Control Unit 1Z Diesel Engine Technology
